AV Sender ProblemSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 04-01-2009 Location: Kent, England
My System: Normal Sky TV with Sky Broadband as well. Digital AV sneder to TV in bedroom. |
I received an AV Sender for Christmas so that I could watch Sky in my bedroom. Setting up was fine, there was no interference and the picture/sound quality is good. I can only get a decent reception on two of the four channels available on the AV sender and I do use the IR eye which enables use of the remote control on the TV in my bedroom. However I do have a problem in that there is obviously some interference from a neighbour who must have a similar product as they are able to control my TV and I can control theirs - this is obviously very annoying when I am watching TV and they keep turning my channel over!! Any suggestions on how this can be prevented would be gratefully received please? Thanks | ||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
| It would help if you can give us the exact make and model number of the AV sender. | ||
| The Following User Says Thank You to HB13DISH For This Useful Post: | dan26 (04-01-2009) |
My System: Normal Sky TV with Sky Broadband as well. Digital AV sneder to TV in bedroom. | Its TOTAL Control and it doesn't have a model number - it was bought from Argos if that helps you? Thanks | ||
| | #4 | |||
| I can't find the user guide or the spec anywhere. See if there is a way to change the frequencies of the transmission, instead of the default values. failing that, see if you can exchange it for another unit from a different make. Also make it less sensitive so it doesn't have the maximum range of the specified distance of 70m. Might need to fiddle with the antennae. | |||
| | #5 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | In the UK these things all work in a small band so interference if there are a few of them around is common. If its a 2.4GHz box you might have to think about swapping it for a 5.8GHz unit. These are quite new so there are likely to be less of them around. | ||
| The Following User Says Thank You to Analoguesat For This Useful Post: | dan26 (04-01-2009) |
| problem, sender |
