poor BBC reception for a week
Sky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally.
Old 08-01-2009   #1
annemarigold's Avatar
Location: Will be Monte Pego on the Northern Costa Blanca
On a Thompson SKY+ HD box this last week or so and living in Surbiton the BBC reception has got steadily worse. Now it breaks up. 986 was Ok now it too is deteriorating (I use that one as originally from West
Country). All the BBC are affected including cbeebies!!
I'm not sure exactly the situation re subscription. 18 months ago it was a Sky+ HD full. A year ago my son-in-law left the home and seemed to have casncelled the subscription so we only get free to air but the Sky+ recording works (mostly!!!) ans so do some of the HD channels.
Any ideas? I've re-booted several times. Do we need to call in an engineer only funds now limited.
annemarigold is offline   Reply With Quote
Old 08-01-2009   #2
Robbo's Avatar
Real name: Mark
Hi, the problem could be caused by many things, it is a matter of sytematically checking each one, including
Dish-misaligned
Tree grown in the way
Dodgy LNB
Dodgy cabling
Faulty receiver.
Obviously start with things that are easy and quick and cheap to check.
Old 08-01-2009   #3
OK so not a problem with the BBC signal then. ITV, ch 4 and 5 etc are OK.
I'd be surprised re a tree at this time of year. the rest I don't think I can check
Old 08-01-2009   #4
Well tonight we have no signal received on any BBC channel. The rest e.g. itv3 are as good as normal. Is that odd?
Old 08-01-2009   #5
Now we've lost ITV, ch4 and 5. Signal test shows no signal on 2nd channel, 1st seems OK. I'm recording Poirot on ITV3 which I can view OK. Looks like it's recording on channel 1 so maybe the other failing and has now gone. I guess an engineer is required. Anyone got any idea at all what it might cost - ball park?
Old 09-01-2009   #6
Robbo's Avatar
Real name: Mark
Probably about £50 call out I would have thought,+vat if they're registered.
Try posting in the members who install satellite systems section
http://www.satellites.co.uk/satellit...llite-systems/
I'm sure that there will be a member nearby.
Old 09-01-2009   #7
jphili's Avatar
My System: Twin monoblock and twin LNB on 80cm transparant dish rigged for twin reception from HB Astra 1 and 2 + TopField TF 7700 HDPVR + TwinHan VisionDTV
I've had 'weird' losses as well from time to time on Astra 2.
Since a couple of days, I'm unable to get anything from TP 10773 H (e.g. BBC 3/4). And that's after checking out the alignment.
Receiving others just fine, like BBC 1/2, ITV #, even BBC HD has signal Strength 99%, Quality 61% even though that TP has acted up on me already as well.
jphili is offline   Reply With Quote
bbc, poor, reception, week
