Sly + record judder Help please !
Sky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally.
Old 30-01-2009   #1
misterminibus's Avatar
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought.
I have an Amstrad 180 $ky + with 2 good signals from the lnb the picture for live tv is perfect yet when I record the picture or sound jumps.
I have swapped hard drives & done the "Housekeeping thing"
I have also done a forced download of the latest software but this the same fault.
Does anyone know a way to fix this, I am out of ideas?
Your help would be very welcome...
misterminibus is offline   Reply With Quote
Old 31-01-2009   #2
My System: Sky+ DRX280 Amstrad, Pc..Dell Dimention C521
It sounds like you could need a 'De-frag', I'm not certain but it might solve your problem.
Defragmentation... Press 'Services' on your remote,
You will then see a Sky screen, there you need to scroll down to option 4..System Setup' and press 'Select'
Then with the remote press '0' then '1' followed by 'Select'
Scroll down to option 7 'Sky planner Rebuild' and press select.
Hope that helps, Cheers Barrie.
barrie.lamb is offline   Reply With Quote
Old 31-01-2009   #3
Thanks Barrie,
But I have already tried that too with no joy
Old 01-02-2009   #4
My System: 3mtr Offset dish, 1.2m Dish Astra 1, 1m Dish Nilesat, 1m Dish Hotbird, Humax Freesat HDR, Cheap FTA Sat box, Quality AV.
Hi Misterminibus. My Amstrad is doing the same. Have tried all the usual tricks, but still no joy. Just had a quick look on Digitalspy. 174 pages of discussion on one thread on this case.
DishDick is offline   Reply With Quote
Old 01-02-2009   #5
What was the answer did it say?
judder, record, sly
