Sky Magic Eye ProblemsSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 09-04-2009 Location: cheshire
My System: sky+ 160 and std digibox in same room. Global SPC4 connected via RF2 on both boxes to lft box - then downlinked to 3 further tvs. |
I hope someone can help - so thanks in advance. I have a Sky+ 160 and a standard digibox in the same room. These are linked via an SPC4 connected to the RF2 output on each box to a loftbox. Three further TV,S are connected via the loftbox - each has a magic eye connected. My problem is that the Magic Eye will only control the Sky+ 160 Box from the 3 other rooms. They will not operate the Std Digbox remotely. I hve checked everything is normal ie both RF Channels are set to on etc but having no luck controlling both boxes. Am I missing something? One again thanks in advance. | ||
| What is an SPC4 when it is at home ? Have you tied swapping over the two incoming connections to it ? | ||
| There is a very fine line between "hobby" and "mental illness" | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Rf combiner for sky receivers. _http://www.tvlink.co.uk/spc4.htm Also check connections for the stand alone box. | ||
| | #4 | |||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | Following the link and reading the blurb perhaps this has something to do with it ?
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | | ||
| | #7 | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. |
| | #8 | ||
| | #9 | ||
| Specialist Contributor Join Date: 06-09-2008 Location: Sunny Scunny
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn. | You have to program the remote to work i dont have instructions to hand but I'm gonna guess sky plus box is in the first (lowest number) port either 0 or 1 on spc4 and thats why you can control this box. You need to program 2nd 3rd and 4th box remotes when they are added to spc4 What you need to do is see what number port std sky box is in they are numbered then its something like tv (one flash) select and blue(2 flashes) the std sky box port number then select(1 flash) on remote- this may not be right but it explains in the destructions you maybe able to download em from somewhere online | ||
| | #10 | ||
My System: sky+ 160 and std digibox in same room. Global SPC4 connected via RF2 on both boxes to lft box - then downlinked to 3 further tvs. | Thanks for all your replies folks. Kenny, you were spot on with your comments - both boxes are now working fine from all locations. Once again thanks. | ||
| | #11 | ||
| Member Join Date: 20-09-2009 Location: england
My System: sky |
Hi Hiope somebody can help. Have sky + installed in living romme and have had it connected to bedroom. Have a magic eye in bedroom. The problem is that it does not work oall the time. If I have been watching sky downstairs for a couple of hours then go upstairs to watch sky I am unable to change channels? The red light flashes on the magic eye when I press buttons on the controller but brings nothing up on screen?? If I use controller upstairs when sky is first switched on it works fine? Any suggestions? Do I need a specific magic eye for sky plus?? | ||
| | #12 | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | As it works some of the time, it seems fairly certain that all you are suffering from is a poor connection somewhere. Check the plug connected to RF2 on the Sky+ Box. Check the connections on the Magic Eye itself. Check the connection to the remote TV. | ||
| eye, magic, problems, sky |
