Problems with input 2Sky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 19-07-2009 Location: south scotland
My System: Sky+ multiroom |
OK, here's the set-up. I have a Sky+ box in the living room. Sky box in a bedroom. Both working great until... The Sky+ box was connected 2 inputs, one output to other rooms direct to the coax coming out of the wall. Wanted to tidy things up so bought double coax socket and a single. Wired the single to the output, ok. Wired the double to the two inputs, then suddenly input 2 not working anymore. I thought the socket may be faulty so tried different permutations. 1. Input 1 cable to input 2 - "No Sattelite Signal...." 2. Input 2 cable to input 1 - "Ditto" 3 Input 2 cable direct again without the socket - no joy. Question is, do you need to have input 1 connected before input 2 works? Also could it be that the input 2 has just given up the ghost? Is there a quick and cheap way of checking the cable to the loft? Any help or advice would be greatly appreciated. Thanks. HowardG | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Welcome, You'll get a signal lock on the signal test screen for INPUT 2 without INPUT 1 connected.... but without a signal on INPUT 1 the box will do nothing and the EPG will not load. | ||
My System: Sky+ multiroom | Thanks for this. I am still not having any joy. I have just got the bloke to send me a replacement for the dual coax socket in case that is faulty. Another thing, friends. As a newcomer to this technology, can you tell me what all the acronyms mean? What is the meaning of LNB, EPG and all the others you fling around. Just dim, I guess, but any explanations would be beneficial to my education :-) | ||
| | #4 | |||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | EPG = Electronic Programme Guide (self-evident: Allocates Channel numbers and provided Programme Information) | |||
| | #5 | ||
My System: Sky+ multiroom | Thanks again. Very interesting. Now the two inputs are working but the output is not. I am going to have to see if I have caused a break in the coax while pushing the surplus back into the wall or even broke the single wall plate. AAAAAARRRRRGGGGGGGHHHHHHH! | ||
| input, problems |
