Thompson 129e163 sound problemSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 22-07-2009 Location: Stoke on Trent
My System: Tomson 129e163 | Hi All, My box has stopped outputting sound via its modulator, all other functions are OK! I think at the same time the modulator channel changed from my setting to the default (re tuning a TV found it but with no sound) Has anyone any thoughts before I do a reset and upset the wife when I lose all the soaps on the HDD! | ||
| Member Real name: jace Join Date: 22-07-2009 Location: hull city england
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv . | try it on a scart lead or try this services 2 sound make sure the sound bar is up or service press 4 then 0 .1 select change rf to 38 then save and try that ... if that dont work might be the mod is faulty .. | ||
| The Following User Says Thank You to jasonx1 For This Useful Post: | PeterBe (22-07-2009) |
| | #5 | ||
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv . | best off using the scart cable really . better sound and picture . if you can remember to change the channel back to 63 in the settings .so you dont get interfernace if thats how you spell it lol .. from the rf | ||
| problem, sound, thompson |
