SKY + stuck on standbySky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| lifes not a practice run Join Date: 27-09-2006 Location: torfaen south wales
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 |
Hi guys my sky+ box is stuck on standby and won,t respond to remote, can,t get anything on it, is it cooked regards Dave | ||
| Specialist Contributor Join Date: 06-09-2008 Location: Sunny Scunny
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn. | Doesn't sound too promising Dave!!!! Have you tried a forced download? | ||
| The Following User Says Thank You to kenny1234 For This Useful Post: | 4dbennett (10-08-2009) |
| Specialist Contributor Join Date: 28-11-2004 Location: Lanzarote, Canary Islands
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3 | It will probably be capacitors in the power supply or the hard drive. As your in the UK repair should be easy enough but maybe not cost effective. Good luck | ||
| The Following User Says Thank You to trigger For This Useful Post: | 4dbennett (10-08-2009) |
| | #5 | ||
| NFL dude Join Date: 15-05-2009 Location: Surrey
My System: Sky+ HD, TM-3500 D+ USB PVR, CD Total (FI) | have you tried pressing the SKY button on remote instead of power on? I've had similar thing happen before, but pressing SKY turned on the receiver. | ||
| | #7 | |||
| Member Real name: Ambriel Join Date: 09-08-2009 Location: UK
My System: Sky+, numerous PCs. | Takes a few minutes to reboot the system but has always worked for us. Is it connected to a working phone line? If it isn't I was wondering if this is why it's having a hissy fit. | |||
| | #8 | ||
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 | | ||
| | #9 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Possible power supply or the hard drive problems. | ||
| | #10 | ||
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 | thanks for the replies guys i checked out repair cost for postage and repair £72 not worth it as its an old model, i,ve also tried rebooting etc, No joy, destined for the bin,i will probably upgrade to a non sky pvr E-bay here i come regards Dave | ||
| | #11 | ||
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315 | any one want it for spares ???????/, | ||
| | #12 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | I'd love to take it off your hands but I'd be severely discomknackerated if I brought another "box of junk" into the house as a project! | ||
| | #13 | ||
| Member Real name: jace Join Date: 22-07-2009 Location: hull city england
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv . | do a full system reset that cures 90% off sky + turn mains plug off hold down the left and right buttons on the navigation circal (the buttons which are up downleft right ) on front off box turn power back on keep holding the buttons untill the play light comes on now press select on front off sky box and let go off buttons the light will flash wait for 5 mins and it should be all back on try it before letting it r.i.p | ||
| The Following User Says Thank You to jasonx1 For This Useful Post: | 4dbennett (13-08-2009) |
| | #14 | ||
| | #15 | |||
regards dave | |||
| | #16 | ||
| sky, standby, stuck |
