SKY+ and Freesat
Sky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally.
Old 10-08-2009   #1
Real name: Gary
My System: SKY+ with a Panasonic freesat TV
SKY+ and Freesat
Hi
I have just got a manual LNB switch which I have been told will manually switch from Sky+ to my Freesat TV.
There are only 3 connectors on the switch. One to Tv and (A) (B). I have two connectors to my sky+ box. How do I connect the two systems?
Kind regards
Gary
SKY+ and Freesat-sky-diag-jpg
ellanvannin54 is offline   Reply With Quote
Old 10-08-2009   #2
Robbo's Avatar
Real name: Mark
Not the best thing to do at all.
Run another cable from the dish straight to the Freesat TV.
If you were for some strange reason determined to use the switch, then conect the Tv one to the incoming cable, then the A to the Sky box 2nd input and the B to the TV.
Old 10-08-2009   #3
Toute Ronde Bon Oeuf
Tivù's Avatar
Real name: Gordon
Assuming you only need one feed for the Freesat TV, remove one only of your Sky+ feeds and then connect it to the "To TV" bit of the switch.
Then connect "Cable A" back to your Sky+ and "Cable B" to your Freesat TV.
Tivù is online now   Reply With Quote
freesat, sky
