Sky+ recording without subscription?Sky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Real name: Nick Join Date: 12-08-2009 Location: Kent
My System: Sky+ |
Hi All this is my first post. I fould this forum using google! I was thinking of canceling my subscription and just using the box to watch free channels but I understand the recorder will not work? Is this true and if so is there any way around it as I have seen card for sale that aparently keep this working? I didnt want to fork out the money for a freesat+ box if I didn't need to seeing as I have a box already. Hope you guys can let me know, thanks. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Welcome, The plus recording facility is £10 monthly I believe without subs or it's a freesat PVR route. | ||
| Regular Member Real name: Chris Join Date: 20-07-2009 Location: South Coast, Hampshire
Blog Entries: 1 My System: Currently, Nokia 1800S with satscan, analogue receiver, Nokia 9800S, D box with DVB2000, 90cm solid offset dish, Panasonic tv with inbuilt freesat. Sky + HD (for the wife, mostly!) | I believe that you will find that your sky box will work okay as a freesat from sky box as long as you keep the card in it, but the recording functions will cease to work as that is part of what you pay the sky + subscription for. The sky + box has two tuners to allow recording on one channel while watching a different channel and I believe you will find that one of them is controlled by the authorisation on the card, so that if you are not paying for the + you don't get allowed to record. But I could be wrong! | ||
| Member Join Date: 05-12-2008 Location: Cumbrian west coast
My System: Sky+ DRX280 Amstrad, Pc..Dell Dimention C521 | As far as I know the 'Recording Function' will only be 'activated' if you suscribe to Sly, maybe someone else will come up with a better answer. Cheers, Barrie. | ||
| | #5 | ||
My System: Sky+ | Thanks for the replys, So it looks like I will lose the recording facility then and the options I have are to buy a freesat recorder box or pay sky? I haven't done any research about the freesat boxes available, I won't want HD (old TV set!) I just want to be able to record. Do any of you have any you can recommend that are cheap to buy, I was hoping to keep the cost down to around the £100 mark? I am assuming I can plug the freesat box into the sky dish and it will work OK? | ||
| | #6 | |||
Yes it's the same satellite feed. Getting a PVR for under £100 may prove difficult. | |||
| | #7 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | I've seen it reported that if the $ly+ box is left unplugged from the mains for a number of months then it misses all the signals sent out to "kill" the recording function of a desubscribed box. How many months exactly? Not known but I wouldn't try reconnecting it in less than three months at least. After that length of time the card would also need reactivation, normally not a problem if you leave the card in an active box overnight, but you haven't said whether you have one of the old yellow house cards or a new white card. If you have a yellow card then this will stop working as an FTV card soon and whether you would still have the recording function after that is completely unknown. Even the white card reaction is unknown as this may behave in a different way to the yellow house card. In short, you have a very difficult set of decisions to make. | ||
| | #8 | ||
| Member Real name: jace Join Date: 22-07-2009 Location: hull city england
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv . | hi its £9.75 a month if you want the recording for sky + as for the recording once you cancel your card it be turned off leaving you with a freeview box you lose all recording there is a hack for the yellow card if you have mutiroom . but the new white card is here now so the hack is usless now the freesat recorders are good . when you bear in mind that £10 a month for sky then you count freesat pvr at £2?? plus its yours and free recording for life seams a good choice | ||
| | #9 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Not only does the recording cease if you stop your Sky subs but any programmes you have recorded from encrypted chanels become unavailable as well..... | ||
| | #10 | ||
| Member Join Date: 17-06-2009 Location: UK
My System: TM6900 Super,1.1m Dish,TM2200 Motor | Before you call sky disconnect your box from the mains and remove the telephone line, then give them a call. Reconnect ur box, but dont connect ur phone line, the PVR will work but all the encyrpted channels recorded wont play back. You can still record all the FTA channels and playback normal, its been working for me for the past two years. | ||
| | #11 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | The phone line has nothing to do with the kill commands - its sent via satellite! | ||
| | #12 | ||
My System: pace hd 9F3004. fitted with a 65cm triax solid dish. beko 32WLA520HD 32" lcd tv . | mhla200 is right . the card still stays on my brother did it with mutiroom the phone light comes on every so often on the box thats it . the only thing is sky has sent him a white card which he dont sub anymore and now has a message on screen telling how to change card . i got a £10 bet he lose he free recording lol | ||
| | #13 | ||
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | | ||
| | #14 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | There are plenty of posts on the DS forum from disgruntled members who have cancelled their sky sub and found they can no longer record. Sometimes if folks disconnect the box and leave it off for 6 months or more then the box misses all the "stop recording kill commands" Of course with the threat of Freesat its quite possible Sky have quietly relaxed their policy in recent weeks. | ||
| recording, sky, subscription |
