How to tell if a stacker is installed on Communal dishSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 25-08-2009 Location: London
My System: Sky + |
Hi All, Very briefly. I live in a communal block of flats and the landlord is rubbish and we cant get access to the dish to check the old fashioned way. We are thinking about getting sky + again ( we have a box from our old place ) . We have a single cable run coming into our flat off the communal dish. The landlord does not know / wont tell us how the cabling is setup. Is there any way to tell if the dish/setup has a stacker installed ? I have been told ( by sky ) that other people in the block have SKY + / Sky HD which is what made me think it might ( there are no other dishes on the block ). I cant get access to the dish and the neighbours ( or the one i asked were less than friendly ). Any help would be great. Cheers Alex | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Be very weary of what Sky tell you. I have had service calls out to many people who order Sky+only to find they only have one feed ![]() Sky will still install a Sky+ box to a property with 1 feed as it will still work just not to its full capability ![]() Its highly likely that its just a five wire system with only the capability to provide one sat feed to each property ![]() I doubt very much if there are any stackers on the system. The only way you are going to find out is by knocking everyones door and asking them ![]() ![]() Nano | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| The Following User Says Thank You to nanochickin For This Useful Post: | alex22 (26-08-2009) |
My System: Sky + | Hi Nano, Thanks for the information you have been more than helpful. To be honest the build quality of the flat is pretty poor to say the least i doubt they would of considered peoples want for sky+ ! It was worth a shot anyway. Its such a pain that SKY+ does not recognise when its only got one input and work accordingly it seems from my research that one has to switch cables etc to record which seems daft. I imagine there are lots of people in the same position. Cheers Alex | ||
| communal, dish, installed, stacker |
