Problems while watching one channel while recording another
Sky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally.
Old 07-09-2009   #1
My System: Sky+
Hi, I've had Sky+ for a month and in the last 2 weeks the box has developed a problem. Sky couldn't help over the phone and an engineed is due to visit this week.
I have no problem recording one or two channels at a time. However, sometimes when recording one channel, I can only watch that channel or BBC1. This happens if you try and access the channel by the TV Guide or input the channel number. All you get is a blue screen and a flashing banner saying Sat Signal Not Available.
In addition, when this problem happens, if I press 'text' or the red button, I get a message saying 'Interactive Services' are not available while recording two programmes. Even though only one recording is happening!
The system set-up suggests that all connections are working so what on earth is going on.
I have tried a couple of Planner re-builds and re-sets but the problem still exists.
citybhoy is offline   Reply With Quote
Old 07-09-2009   #2
Toute Ronde Bon Oeuf
Tivů's Avatar
Real name: Gordon
Are you using the Box with two separate feeds from your Dish or are you using only a single feed?
If two feeds, have you checked for loose connections? Have you swopped over the feeds to see if the fault remains the same or if it changes in nature?
Tivů is offline   Reply With Quote
Old 07-09-2009   #3
satelliteman's Avatar
Real name: Paul
Yes, normally happens if you loose signal on input 2. As said check/swap connections over to determine if the fault lies with the LNb/cable connections.
satelliteman.
An Installers Choice
Follow us on
Old 08-09-2009   #4
My System: Sky+
Two feeds from dish.
Engineer came this morning. Checked everything and said that the only thing he could do was change the box. He said Sky + boxes were hit and miss. Sometimes they are ok but sometimes they pack up after a few weeks.
If this is true, then what the %*$@ are Sky playing at ?!?
channel, problems, recording, watching
