Using sky multi room in different locationSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 04-10-2009 Location: London
My System: Laptop and sky |
Hi I would appreciate it if you could pls try and answer my question. I have a second home in london but my primary address is in manchester. I have sky with sky sports in manchester. If I was to order a sky multiroom box and card for this address but use it in my second home in london would I get all the channels I get in my primary home in manchester. Thank You | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Multiroom boxes have to be connected to the same operational phone line at all times specifically to prevent folks getting a cheap sub in a different location. This is actively monitored & if too many checks fail you will get billed for two full subscriptions. Of course theres nothing to stop you just carrying the box backwards & forwards when you go to the second place - as long as its regularly coonected back up again when you get home its unlikely to cause problems. | ||
| | #4 | |||
| Specialist Contributor Join Date: 06-09-2008 Location: Sunny Scunny
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn. | Then they will run you a phone line. Ive been lead to believe......(plz correct me if this is wrong) If you dont have it connected and you miss 3 callbacks you receive a warning letter. If your receiver isnt connected at any stage for the following 3 callbacks after the letter, then they will bill you for x2 subs instead of x1 sub and x1 £10 multiroom. If your box receives all 3 callbacks after the letter your slate is wiped clean. Callbacks are usually sent on or around install date | |||
| | #5 | ||
| Grimm Member Join Date: 08-03-2009 Location: Blackburn, Lancs
My System: 1.1m Triax Motorised 45e-45w, Raven 60cm fixed, Fortex Zeta PVR, Technomate TM500 | It is not unknown for people to get away with doing what you want to do without any problem at all Generally though If you start missing the callbacks you will start getting letters. | ||
| I've booted up, I've patched in, I'm online, offline, downloaded and extremely cheesed off! | |||
| | #7 | ||
My System: Motorised ASC 1.2m,1224 Supermount with C120 Invacom Quad LNB with Matched Feedhorn. | | ||
| | #8 | ||
| Member Join Date: 14-10-2009 Location: leeds
My System: not listed | they will send out 3 letters , when u recieve the 3rd letter that when sky will start charging u, you digi box will do what called a "callback" 1ce a month, round about the same time of every month, sky can trigger the "callback" from their end or you can do the callback youself, on the old software style menus 1 press services 2 highlight and press select on system setup (option 4 on your tv screen) 3 (make sure you can see picture setiing and sound settings on your screen for this part) press 0, 1 and then select this part takes you into the installer setup menu 4 highlight and press select on new installation "there will be a message displayed saying please ensure your sat dish is correctly alighned and your viewing card is inserted" press select 2 times to get astra channel scan now scanning please wait after about 2 mins it will say channel line up complete, this is the point where you need to make sure no one in using the phone, when you press select at this point the digibox will try to send the "callback" back to sky most advisors wont know u triggered the callback from your end unless they look really hard for it, for those who have the hd digibox with the new guide layout 1 press services 2 highlight and press select on setting (the option with the pic of a spanner) 3 ( you should see picture highlight if done correct) press 0, 1 , select 4 u should be in the installer setup menu and look for install and press select at this point the same messages shold appear as above and just follow it through | ||
| | #9 | |||
| Member Join Date: 08-04-2009 Location: Oxford
My System: Sky HD, Sky Amstrad PVR3, Technomate TM9100, Targa TSR5200, Fortec Star 5100CI Diamond plus half a dozen more |
| location, multi, room, sky |
