Another 'Sky plus - one feed - flat/apartment' threadSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 13-10-2009 Location: North West, UK
My System: Sky+...hopefully |
Hello. I'm about to have Sky Plus fitted in an apartment which only has one feed. I know I won't b able to use all of it's features - but what exactly will/won't I be able to do? Thanks very much. | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Welcome, In simple terms, you'll be unable to record one program and watch another as this requires the two feeds. | ||
My System: Sky+...hopefully | If I'm at work, and I want to record something, do I have to set Sky to on the channel that I want to record or will it automatically flick over? Can I pause/rewind something while I'm watching it? If I have a 1 hour program set to record on BBC1 at 7pm, and want to set something to record on BBC2 at 8pm, will it record both? Also, do you know what this is (pic attached) hiding in my electric cupboard? Genuintely appreciate your help. | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | It's a signal splitter. Normally used for splitting a strong TV signal to feed two TV sets. If someone has fitted it to try get two satellite feeds for a $ly + box from one satellite feed then it ain't gonna work properly! I don't have a $ly + box so can't answer the other questions. | ||
| | #5 | |||
| aka Skyman Join Date: 13-06-2003 Location: Limassol, Sunny Cyprus
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii ![]() |
I know the normal sky receiver has an autoview feature which will change channels when the selected program starts but I dont think the sky plus box has this. The live pause and rewind should work. | |||
| | #7 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Ah bingo, looks promising but might also be an un-terminated RF feed to another room in the flat. Some sparks wire that way. Check for additional points in the bedrooms. | ||
| | #8 | ||
My System: Sky+...hopefully | No other points in the flat. If I mention this to the installer when he visits next week, will he check to see if it's live/works? Or is that out of his remit? | ||
| | #9 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Might possibly be the connection to the splitter shown in the above post Chris but yes, the installer should be able to see if it's live. | ||
| | #10 | ||
| Member Join Date: 17-02-2009 Location: North West
My System: Freesat+ | How old is the flat? If brand new there's a good chance the extra cable may be fed from the multiswitch. If a few years old its likely a single cable was dropped to each flat from the multiswitch. This is a 'problem' on the majority of existing IRS systems, the 2nd feed was not envisaged (i.e. before sky+). If you only have a single feed then you will need either get an extra cable fed in, if this is practible/possible, or you can use a stacker/destacker to combine 2 if feeds into 1 then split back to 2 at the back of your stb for input to both feeds. You may also have a problem in that the existing multiswitch has no free outputs for you to tap into. So you will need then to replace the multiswitch or cascade another multiswitch inline. If you have to start messing with the existing IRS system then its going to cost a fair bit to enable Sky+ | ||
| | #11 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | | ||
| | #13 | |||
The SCR device though for Sky+ is only compatible with Pace PVR V3 TDS470N and TDS470NB 08/05/2007 01/12//2008. | |||
| feed, flat or apartment, pkus, thread |
