sky+ input 2 no signal and lock indicator not lockedSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Member Join Date: 18-10-2009 Location: scotland
My System: sky+ wireless router |
this only started recently not long after the new cards issued it worked fine before . I've tried full reset and planner upgrade and system update no luck the signal comes and goes every couple of seconds . So i can't record unless im watching that channel. Help | ||
Welcome to the forum hulltoon Well it seems like you have already been reading lots of info and to be honest having done what you say I cannot think of anything else to be done, from what you have done it seems to be an stb fault as the fault stayed with the port 2 | ||
| | #5 | ||
Perhaps not as much reading as I thought stb = set top box ![]() I have to say though I do not understand how it could be working successfully if you are watching the same channel it is still using the tuner that appears to have a fault to record, do you definitely have two separate feeds for the stb? | ||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Multiroom makes no difference, the LNB swap around proves that there is likely to be a problem with the second tuner, but to make sure, have a look at the "F" connectors and make sure that the cores are long enough to make full contact. If they are screw connectors, they are prone to coming unscrewed when installing. | ||
| | #8 | ||
My System: sky+ wireless router | the signal was there today but as soon as i recorded a channel the signal was gone then came back when i stopped the recording the stb is near 4 years old so i may need a new one | ||
| | #9 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | | ||
| | #10 | ||
| Member Join Date: 14-07-2008 Location: UK
My System: Sky+ | What model is your box? (Check here: _http://stuckinstandby.co.cc/index.php/how-to-identify-your-sky-plus-box) I don't suppose it's an Amstrad DRX280? Sounds quite like the problem in this thread: Problem with DRX280 Amstrad. Never did work out a fix. | ||
| Last edited by satelliteman; 3 Weeks Ago at 07:17 PM. Reason: Deativated link | |||
| | #11 | ||
| Member Join Date: 11-10-2009 Location: Leeds UK
My System: DB 7020s |
S = Set T = Top B = Box or in laymens terms your receiver? Few things to try to locate the fault. Is your multi room a sky + STB if so swap them around and see if you have the same problem on the STB. You say you have tried a reset but how did you do this? You need to power up your STB holding in the backup button untill it says upgrading or installing this will install the latest software on your STB. | ||
| indicator, input, lock, locked, signal, sky |
