tranfering sky+ to pc
Sky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally.
Old 25-09-2005   #1
has anyone ever tried transfering tv programs from the sky+ box to a pc? ive got a vivo card and was thinking about it, is it easy?
doggy is offline   Reply With Quote
Old 25-09-2005   #2
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
Are the recording not encrypted - they need the + box to play?
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 25-09-2005   #3
not sure what you mean.
basically i want to record tv on my sky+ box then transfer it to my pc to burn to dvd, if its possible
Old 25-09-2005   #4
Amo Amas Amant Admin
Topper's Avatar
Ermmm
You do not seem to understand you will only be able to view those programs on a sky+ box as they are encrypted. When you are viewing them they are decrypted by your card. If you burn to DVD they will be encrypted. At least that is my understanding of the situation although I cannot claim proof of experience.
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 25-09-2005   #5
oh i see, thats pretty shity is it not? i suppose i got buy a home dvd recorder or transfer to vcr and then to the pc
Old 25-09-2005   #6
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Toppervte33h is correct about the recordings being encrypted on the hard disk and being decrypted on the fly so that you can see them on the TV.
However, I can't see why you can't take the output from the $ly+ box and running it into your DVD recorder providing you don't mind it having been converted into analogue first of all. If you want to stay digital then it's not possible I'm afraid.
PaulR is offline   Reply With Quote
Old 25-09-2005   #7
PaulR's Avatar
Further thoughts. If your PC has a video capture facility then this could also work if you want to record to the PC's hard disk.
Old 26-09-2005   #8
i was thinking about that myself paul. surely the cable leaving the sky+ box is not encrypted, after all its just going to the back of my tv. i do have quiet a fancy graphics card that has video in video out. i also have a standard tv capture card, but thats not fitted at the moment
Old 27-09-2005   #9
PaulR's Avatar
Go for it...
Old 27-09-2005   #10
Yup, there are various ways you can do it depending on price/picture quality you want.
A VIVO card will give you full uncompressed video - if you want to record at full resolution you will need about 26MB/s of disk space. Of course, you can compress on the fly to divx/mpeg depending on your processor.
A PVR card (Hauppauge for example) will do the mpeg enoding for you, allowing you to capture at a rate more like under 1MB/s.
S-video from your sky box is the best signal - composite will probably give you a poor signal (but an ok one if your not watching on a massive TV).
If you want to do this regularly and don't mind spending a bit, the best picture you will get is taking the digital feed from the sky+ box and capturing that - will cost you about £300 to get all the equipment ... but you can't get any better! (hunt for sky+ SDI modification).
Any signal coming out of the Sky+ box is unencrypted and (unless you ripped out the sky+ hard drive) you would have trouble to get hold of the encrypted content.
Al
marble is offline   Reply With Quote
Old 28-09-2005   #11
i didnt relise the sky box had an s video output, that would work fine. my graphics gard came with some cyberlink software power director and dvd i think. ideally i just want to copy the odd film or football match to my pc, nothing comercial.
Old 28-09-2005   #12
PaulR's Avatar
I'd forgotten about that. It'll only work with the first series $ly+ box though - see http://www.irj-tech.com/skysdi.html
Old 29-09-2005   #13
Very few Sky boxes come with s-video ... I think only certain Grundig ones and Sky+ ones (if there isn't an s-video connector on the box, I'm 99% sure you won't get one through scart). If s-video isn't an option, I think all Sky boxes come with RGB out and a £35 box from Maplin will give you an s-video signal from this (though I've heard both good and bad stories about picture quality).
Yeah, the SDI mod only works with the Pace 3000 box I think - I picked on up on Ebay for £50, the mod was £110 and the capture card £130 ... if you are good with a soldering iron, this is all you need ... if you pay someone else, they'll most likely charge you a few hundred quid! It's worth asking local repair shops if they'll do it ... it's not hard, just fiddly (make sure you don't consume alcohol beforehand!).
Al
Old 29-09-2005   #14
I record from Sky+ to dvd ram disk (panasonic dvd recorder), then dvdram drive on the pc to hard disk, convert to mpeg, edit and add chapters and menu in tmpgenc and burn with nero. Job done.
Stevie
pc::
steviewilson is offline   Reply With Quote
Old 03-10-2005   #15
mines has got s video so ill pick up a cable soon and try it out
Old 03-10-2005   #16
got the cable today, plugged it and started a programme from the hd, nothing. my pc doesnt pick it up. is there anything in the menu of the sky box that i need to set to on?
Old 03-10-2005   #17
Super Minty Mod
PoloMint's Avatar
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections
What capture software are you using, and have you used the S Video in before?
'All you need is duck tape and WD40; if it moves and it shouldn't, use duck tape - if it should move and it doesn't, use WD40'
PoloMint is offline   Reply With Quote
Old 04-10-2005   #18
PaulR's Avatar
Assuming the TV has an S-video input try feeding the TV directly from the digibox. This will show whether there's an S-video signal at the plug or not.
sky, tranfering
Similar Threads
Sky throws down gauntlet net1 Daily Satellite and Broadcast industry News 11 25-01-2006 03:06 AM
BSkyB commits to free Sky One net1 Sky Digital (BSkyB) and Astra 28.2 East General 2 09-11-2004 01:14 PM
Sky unveils plans for Plus net1 Sky+ (Plus) and PVR Systems 0 03-03-2004 08:24 PM
Changes To Sky Movies net1 Sky Digital (BSkyB) and Astra 28.2 East General 0 20-10-2003 07:00 PM
Will the BBC's satellite dream ever take off? net1 Daily Satellite and Broadcast industry News 0 26-06-2003 08:49 PM
