Sky+ No 2nd SignalSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Part Timer Join Date: 06-10-2005 Location: that would be telling
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | HI NEW MEMBER JUST FITTED SKY+ BOX GOT OFF EBAY AMSTRAD DRX180 PUT NEW QAUD LNB IN TWO CABLES SEEMS TO WORK FINE BUT GET NO SIGNAL ON THE 2ND LINE WHEN I GO TO SIGNAL TEST. I HAVE UPGRADED TO SKY+ (sky was not very happy about the phone line not being connected) SEEMS TO RECORD NOT ON THE TIMER BUT THATS FOR LATER TO SORT OUT OR IS THIS BECAUSE OF THE 2ND SIGNAL PROBLEM.IF YOU CAN MAKE HEADS OR TAILS OF THIS HELP THANK YOU. | ||
| | #2 | |||
| Specialist Contributor Join Date: 13-02-2005 Location: near Limassol, Cyprus
My System: 3.1m Famaval on 28.2, 1.5m offset on 19.2e, 13e & 7e all mixed in a spaghetti of wires and going into a dream thingy. | Sometimes the signal indicators can be misleading. Does it actually do the job. Try watching one programme and recording another. Then record two at once. If it does this okay then don't worry too much at the moment. PS NO NEED TO SHOUT - lower case is just fine Cheers Nick
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Sounds like a faulty box, I presume that you have tried swapping the inputs? | ||
| | #4 | |||
| Super Moderator Join Date: 24-08-2003 Location: Dublin....Ireland
My System: Dusty Dreambox 7000s, & Sky HD. |
Do A software reboot and they should appear. Thats after you know that power is coming in on both cables. To do a software reboot, hold the back up button down on the receiver, then disconnect the power lead form mains while holding the back up button down, count to 10 and put power lead back in until you see info on screen saying software programming, then let the back up button go. Should be ok now, always works for me. Lets know how you get on. | |||
| Happy Dreaming | ||||
| | #5 | ||
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | did software reboot still no 2nd signal i record two prgrammes and the signal looks ok thank you record timer does not seem to work but one thing at a time | ||
| | #6 | ||
My System: DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr | here we go 2nd signal now gone when i try to record two programmes and watch a different one it says to watch this programme you need to cancel one of the programmes you are recording or something like that.then i can not recieve any signal at all for a short amount of time turn off/on try different channels till it comes back the lnb wotsit in the systems thing shows 9.70 on one and 10.00 on the other is this right any ideas thank you | ||
| | #7 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No, it should say 9750 low band and 10600 high band. | ||
| | #8 | |||
| | #9 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Still sounds to me like the box is faulty, but last resort is to go into Services/ System Setup/ 01Select/Full System Reset. If that doesn't work, then the box probably needs repairing. | ||
| | #10 | |||
| | #11 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No, it isn't the same as a software download, this purges the harddrive and recording history. But I think that you will probably end up sending it back, remember to remove your card when you do. | ||
| | #12 | |||
| | #13 | |||
| | #14 | |||
| | #15 | |||
| | #16 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | It is the box, it is because you have no second input, or at least the box thinks that you don't. | ||
| | #17 | ||
My System: Dusty Dreambox 7000s, & Sky HD. | Think you better send the box back. You would get a message to contact sky if recording wasnt activated on your card. | ||
| | #18 | |||
| | #19 | |||
| 2nd, signal, sky |
Similar Threads | ||||
| BSkyB commits to free Sky One | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 2 | 09-11-2004 01:14 PM |
| Sky unveils plans for Plus | net1 | Sky+ (Plus) and PVR Systems | 0 | 03-03-2004 08:24 PM |
| NO 2nd TV Signal From Sky Box | ddonlon | Sky Digital (BSkyB) and Astra 28.2 East General | 4 | 06-12-2003 04:43 PM |
| sky sat signal weak | sky do i bother? | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 2 | 07-10-2003 10:00 PM |
| Will the BBC's satellite dream ever take off? | net1 | Daily Satellite and Broadcast industry News | 0 | 26-06-2003 08:49 PM |
