Banging head on wallSky+ Plus General and technical support forum for the Sky+ personal video recorder system and PVRs generally. | |
| Sorry I'm a bit Dim Join Date: 11-01-2004 Location: NW UK (Lancashire)
Gotta Zone 2 dish with a Thomson single LNB 0.6 whatsits & the signal strenth shows 2/3 (Same wiv the quality) Just changed the LNB to a Cambridge Quad 0.6 whatsits too, & the signal has dropped to 50% (Both readings) WTF is that all about ? ![]() | ||
| Super Minty Mod Join Date: 31-12-1999 Location: Fife, Scotland
My System: 1200cc with 100,000,000,000 neurons and 100,000,000,000,000 connections | Could you have moved the dish very slightly when installing the LNB? However what’s more likely is that either the skew is slightly off, or the additional weight of the quad LNB is pulling the dish arm down slightly more than the single one and so the LNB is slightly too low. You could start by adjusting the skew slightly (as it’s the easiest to adjust) and if you still don’t get much of an improvement it may be the height of the LNB. Also remember that different makes and models of LNBs wont produce exactly the same result, so don’t aim to get exactly the same readings as before, but you should be getting something more similar than what you have now. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | This new Thompson LNB appears to produce excellent signal readings (if it is the cylindrical style), up to 10% better than the standard. Was producing 72db on the meter where a normal one would be in the mid 60s on a standard minidish. | ||
| | #5 | ||
| Yeah that thomson jobby has just gone on my bro's 42cm channel master It sucked a passing jet out of the sky.......... Should have a warning on those... Left my meter @ his house again, so my lil problem Is gonna have to wait | ||
| banging, head, wall |
Similar Threads | ||||
| Adjustable wall mounts? | DuncanEK3 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 25-03-2004 05:35 PM |
| Waveriders Petrol Head Forum! | waverider | The Meeting Place | 5 | 09-03-2004 11:17 PM |
| Too big for wall mount? | j.m. | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 11 | 22-01-2004 01:03 AM |
| Lachlan Murdoch to head Fox TV | net1 | Daily Satellite and Broadcast industry News | 1 | 09-01-2004 12:57 PM |
| Banging Headache | Burnt Chips | Magic Module | 10 | 17-12-2002 07:03 PM |
