Missing Favourites | |
| Member Join Date: 30-03-2004 Location: West Sussex
| Hi I wonder if anyone out their can help me with this problem. Following a local power cut I have been unable to use the favourites funcyion on my Sky+ box. When I try to set a favourite I get the following message "There is a technical fault Please try later". So far I have tried a software sytem reset from the install menu, a software update from the install menu as described by rolfw and lastly a power-on system reboot using the process described so completely by net1 using the navigation buttons but all with the same result namely I still have the problem. Given what I've already done the favourites are probably stored in some nv ram somewhere so is their the equvalent of a cmos battery link as in P/Cs that will clear the ram?? Any help greatfully received | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | Have you checked that you still have the favourite channels still ticked (Servuces - Favorite Channels)? If they are still there try deleting them (yellow button and finally select) and then reinstallinng them. PaulR | ||
| Hi Paul No the problem occurs as soon as I try to select option 7 from the menu so there is no chance to delete them. If I press the Favourites button when watching a channel I get the message explaining how to set up the favourites option which kind of suggests that the box thenks they don't exist. Prior to the problem I had the maximum number of favourites set (30? I think). System details are: Pace Box, Model # 2.057A2, Ver # 9F2106, O/S Ver 1.3OBF, EPG Sky+ 1.26 v2. Any further ideas greatfully accepted. The Old Fella | ||
Similar Threads | ||||
| low band channels missing | RESCO | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 7 | 05-12-2003 08:33 PM |
| missing canal blauw | doggy | Seca/Mediaguard system | 18 | 04-12-2003 03:23 PM |
| Missing channels | pizzabeef | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 09-11-2003 03:19 PM |
| Saturdays missing Tv listings | Dean131 | What's on listings | 0 | 11-10-2003 10:46 PM |
