Extract all recordings from Sky+/SkyHD (non only the FTA). | |
| Member Join Date: 10-06-2008 Location: UK
My System: SKY HD |
If no one have already try, i can confirm that is possible to extract and decode the movie form a Sky+ box (legally). The procedure is quite simple (but a little longer) : 1) Extract the .str files with +Extract. 2) Decode with Offline Descrambler 2.50, using a CSA engine (like FFDecsa.dll, MakroCSA.dll o CSA.dll) as CSA Engine (from progdvb binary) and using NCEMUCAM as softcam, of course using a serial smartmouse (in phoenix mode at 3.56 mhz) with a official and active Sky smartcard in it. 3) Clean/remux the decoded .str file to an mpeg file with a .ts processor, the ProjectX works perfect for this job (but many other is suitable as well). This procedure works with mpeg2 files, i can't confirm if it works with Mpeg4-H.264 HD recording of Sky HD boxes. I think that this procedure is legally because you MUST use your ACTIVE smartcard to decrypt the files and the procedure purpose is onyl & simply to re-use your personal recordings, exactly you can with many other satellite receiver with pvr functions (like dreambox or clarke tech). Regards. | ||
| The Following User Says Thank You to Big_Blue For This Useful Post: | meditating_hamster (05-07-2008) |
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | Good news for people with $ly + boxes. Up until I read your post I would have said it was impossible.
__________________ PaulR As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after. | ||
| Member Join Date: 09-08-2008 Location: London, UK
My System: Sky+ | For anyone attempting this, it seems this works for Pace V2 boxes, but not Pace V1. Other box models as yet untested. Last edited by pcbbc; 3 Weeks Ago at 01:22 PM. | ||
| | #5 | ||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.4.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | How do you connect to the box in order to extract the files? Is there an ethernet connector or other interface? | ||
| | #6 | |||
My System: Sky+ | You will need to open the box, remove the hard drive and connect to your PC via a USB adapter. | |||
| | #8 | ||
My System: Sky+ | | ||
