Thomson DSI 8210 no signal with motor
Thread Tools Display Modes
Old 19-07-2008   #1
My System: Technotrend 3200, Triax 80cm dish, Pace 2600C1, Thomson DSI 8210, Raven 60cm dish. Skyline DSR 6000, Stab motor.
Got a new Thomson DSI 8210 Sky+ box and connected it to my 80cm dish, which has about 25 metres of cable and a stabs usals motor. Many channels reported this message "no satellite signal being received" error number 28. So I removed the cable from the motor and connected it directly to the LNB and hey presto, all channels are back on. My cable is the type with hollow insulation and the cable from the motor to LNB is a piece of NTL cable with solid foam insulation. Is the motor causing a drop in signal?
I've also got a Pace 2600C1 Sky receiver and it works okay with the cable going through the motor, although I've heard this box works with weak signals.
thedavid is offline   Reply With Quote
Old 19-07-2008   #2
Amo Amas Amant Admin
Topper's Avatar
Well
Cable with an airgap is not for satellite use, that is why the performance is poor, it cannot handle the high frequencies
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 19-07-2008   #3
Robbo71's Avatar
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Any of the type '100' approved satellite cables should do the trick, eg wf100 (foam dielectric) or WC100( air- spaced).
Check that the air-cored cable is double screened and the correct type for satellite.
The cables with silver coloured foil and braid such as the virgin stuff are not supposed to be as good.
Yes, the motor will cause some attenuation. 3 or 4 dB I believe.
Also kinked or badly bent cable will cause a problem, the air-spaced dielectic cable is more prone to this.
Robbo71 is offline   Reply With Quote
Old 19-07-2008   #4
Sorry, I meant air spaced not air gap. I got the cable from a sky engineer who left 50m behind, but that was for sky analogue. The cable has braid and foil.
Old 19-07-2008   #5
Robbo71's Avatar
Looks like low quality stuff compared to what I normally use, the braid coverage is lower. To be able to rule it out, I would be tempted to get some wf100 or similar.
Old 19-07-2008   #6
Thanks, I'll buy some wf100.
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
