Sky Plus recording problems | |
| Member Join Date: 23-07-2008 Location: lancs
My System: thomson sky plus box, broadboand via tiscali |
Hi, I recently had to disconnect the dish input connections at the rear of my Thomson sky + box. Having reconnected it I can't record from the planner and if I try it then it shows that channel as 'no signal being received'. I can record direct (without going into the planner or tv guide). I've checked the signal test and input 1 is fine but input 2 is not showing anything other than 'not locked' . Please help! | ||
| | #2 | ||||
| Super Moderator Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N |
First thing to do is upgrade software and reboot as follows: >Turn off power >Hold backup button on receiver in whilst applying power again >Hold the button in until all lights on receiver light >Wait 10 Minutes until box turns to s/by >Wait 1 Minute, switch on >You will see 'searching for listings', please wait >Leave for further 2 minutes to see if signal lock on both ports. If not then you may have further problems Satman
__________________ | ||||
| The Following User Says Thank You to satelliteman For This Useful Post: | seggy45 (25-07-2008) |
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Another thing to check first is that you have screwed the 2nd input in properly, and there is enough of inner core poking out the end of the f-connector, and that the connector is still on the cable properly.
| The Following User Says Thank You to Robbo For This Useful Post: | seggy45 (25-07-2008) |
| aka Skyman Join Date: 13-06-2003 Location: Limassol, Sunny Cyprus
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii ![]() | And then swap over the connectors of input 1 and 2 and see if the same input is no signal
| The Following User Says Thank You to Zorba For This Useful Post: | seggy45 (25-07-2008) |
| | #5 | ||
My System: thomson sky plus box, broadboand via tiscali | Thanks, tried all the above with no success, when i swapped the inputs over there was no signal on either input, I take it this isnt looking too good? | ||
| | #6 | |||
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Maybe a poor termination on the LNb or faulty LNb
| | #7 | |||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
If you only left it in standby and then disconnected then this is the most likely source of your problem. More than likely a goosed lnb. However there may be hope if you have a look at the lnb it may be a quad output instead of dual output and one of the two remaining outputs may be OK, worth checking.
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | |||
