Sky+ Cabling | |
| Member Join Date: 07-03-2005
My System: Sky+ |
An independent installer is installing sky+ for me next week, however I have the following problem: When the cable was installed from a faceplate in the lounge into the loft, the spark forgot to label each one. Is there an easy way to identify each cable before he gets there (e.g. by passing a current to it and testing with a multimeter), or is it a case of 'trial and error' when the installer arrives? Any suggestions would be gratefully received | ||
| Specialist Contributor Join Date: 01-01-2000 Location: uk
| Hello Iwan Assuming you have two or more coaxial cables starting in the loft and ending on wall plates in the lounge. You could short one of the outlets in the lounge by putting a piece of wire beetween the inner and outer connectors, then go to the loft and try to pass a small current through each cable. The one which returns the current to you is the one you shorted. Hope this makes sense - if not come back. Regards W. Hole | ||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | If you don't have a multimeter. Get a battery (the small rectangular ones with the + and - at the top) and connect the centre core of the coaxial cable to one end and the copper braid to the other. Use a torch bulb at the other end and the wire that lights the bulb is identified. But I'm sure the S*y engineer will do it in seconds for you. | ||
Similar Threads | ||||
| Multi-room cabling | skyeliner | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 1 | 17-09-2005 10:04 AM |
| DIY LAN Cabling | Llew | Computer Discussion | 5 | 27-04-2005 06:05 PM |
| Cabling | wolsty | Computer Discussion | 15 | 13-04-2004 04:44 PM |
| Will this cabling set up work?? | cslogg | Terrestrial Television, Digital and Analogue | 8 | 11-02-2004 09:39 PM |
