Replacement HDD for Sky+ | |
| Member Join Date: 17-12-2005 Location: Essex, UK
My System: Sky+ |
Hi All Just came across this site while trying to find out why my Sky+ box wouldn't come out of standby mode. Found out the the HDD is toast...... I've managed to get the unit working again by installing an old 12Gb drive I had lying about but this isn't going to take long to fill up. Can I go out and by any HDD or does it have to be a specific make (i.e Maxtor)?? I have tried searching on this but I only picked up some very old posts. Any advice would be appreciated Many thanks Russ | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | I believe that the slower drives are better, as they are quieter and use less power. Maxtors seem to be best for pace boxes, but the Amstrads seem to like Samsung drives. See here http://www.xtendedplay.co.uk/
__________________ | |||
| Ding Dang Doo Join Date: 31-01-2004 Location: Scotland
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life! | The older 'slower' drivers are becoming harder to find and more expensive. The prices on that site are high IMHO Maybe someone here has an old drive they want to sell cheap! | ||
| | #5 | ||
| Member Join Date: 17-12-2005 Location: London
My System: Sky+, Samsung 32" TV (LE32M51B) | I've had personal experience with XtendedPlay... I bought a drive upgrade kit from them a couple of months back. Their service was prompt and friendly - the drive arrived next day and included a torx wrench set and instructions... The 250GB drive they supply spins at 5760RPM and they set all the acoustic management settings on the drives firmware to 'quiet' mode, so there was no need for me to take my PC to bits to configure up the drive. I'd recommend them if you don't mind paying a bit more... JonB | ||
| | #6 | |||
My System: Sky+ |
IF I went for say a Maxtor drive that spins at 7200rpm, how necessary is it to upgrade the cooling on the box or is it just a case of more noise? | |||
| | #7 | ||
My System: Sky+ | Found this drive http://www.komplett.co.uk/k/ki.asp?sku=308644&cks=SPC Looks OK to me, what do you reckon? | ||
| | #8 | ||
My System: Sky+, Samsung 32" TV (LE32M51B) | I've read in a number of place that the Sky+ boxes are very sensitive to heat (unlike my trusty old TiVo), so I would imagine that installing a slower spinning drive would help with the reliability of the Sky+ box. | ||
| | #9 | ||
My System: Sky+, Samsung 32" TV (LE32M51B) | One other bit of information on upgrading the hard disk drive in the Sky+ box... Sky+ boxes do not work with some hard drives due to the spin up speed (I believe it needs to be <8 secs). It seems certain models of Maxtor drives work well in Pace boxes (but not all Maxtor drives) and Samsung drives generally work well in Amstrad Sky+ boxes. However, it seems a bit of lottery... That's why I ended up buying it from someone who had tested it for me!!! | ||
| | #10 | ||
My System: Sky+ | Well after sleeping on it and getting no where with Sky, I've opted for the xtended play 160 upgrade :-) Cheers for all the advice and I'll let you know how the install goes. Russ | ||
| | #11 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Will be interested to hear how you get on Russ, as a pal of mine is thinking of the same upgrade, as his HDD is starting to play up.
| | #12 | |||
My System: Sky+ |
| | #13 | ||
My System: Sky+ | The drive arrived today (only ordered it Sunday night) Took 20 mins to install including leaving the unit to "discharge" for 10mins after I unplugged it from the mains. Seems to be working fine with all the functionallity of the original. Well impressed so far | ||
| | #14 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Thanks Russ, wouldn't it be nice if everything went as smoothly.
Similar Threads | ||||
| Replacement mount for dish | cinnamon_oil | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 14-09-2005 08:42 PM |
| Analogue Receiver Replacement for SECAM L | James C | Analogue systems | 12 | 03-09-2005 01:30 AM |
| Replacement fan for Thomson plasma | Jonny D | The Work Bench and Soldering Station | 1 | 22-07-2005 01:00 PM |
| Humax VACI replacement PSU board | stupidlogin | Digital systems | 2 | 06-04-2005 01:09 PM |
| Thor bird replacement | net1 | Daily Satellite and Broadcast industry News | 0 | 16-02-2005 07:14 PM |
