first experiment on ASTRA 2D in C.ITALY | |
| | #26 | ||
| Specialist Contributor Join Date: 22-06-2005 Location: UK: Kent. Spain: Madrid.
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | Regarding skew calulators: I have just posted the answer to your question in the other thread mentioned above. see also _http://www.satlex.de/en/azel_calc-params.html? | ||
| | #27 | ||
| Regular Member Join Date: 12-01-2005 Location: naples italy
hi to all, just wanted to inquire to all were to find a updated EIRP for astra 2d in southern italy. i was told the signal should reach here at 36 dbi and it would require a 3.5 to 4 meter dish. in rome the archive shows some one with a 2.4 meter v-sat system with a prodeline adjistible scaler rings and a 4 inch feed horn with a f/d of .8 and 39 degrees feed. i am using QTF 31 and someone is using a different ivacom c120 lnb. also since this is a free to air on the bbc and itv there should be receivers better and more senstive than the sky box that will go lower that -65 this will be for super sensitive tuner thanks for all ralph ![]() ps how about geting bbc in streaming whats is the quality looked on the net and got sky news as a trial and it looked bad thanks ralph Last edited by ralphmagno; 01-05-2008 at 06:31 PM Reason: insertd picture | ||
| | #28 | ||
| Regular Member Join Date: 08-01-2007 Location: italy
My System: 3.7 MESH | nice photo my friend and nice..........................position for adjust the lnb?????!!!!!!! eh eh eh!| tomorrow i will send mine with my little bear after a day of searching there im try the conclusion to wait the new 4 from invacom because the one is at limit at me i am in the border both for astra 2 d southern limit with acceptable diameter and intelsat 902 ( middle east beam ) iranian mux at 11555 v that i can receive with some pixelation during morning hours 12,00 / 1,00 pm after 4,00 pm both astra 2d and intelsat 902 go down and the signal decrease very strong ah ps ralph why do you dont try 62 east middle east beam 11555 v 27500 there in napoli i think you have a very strong signal like coviello i think! now i go to " CENA !" see you next time | ||
| | #29 | ||
| Member Join Date: 23-02-2003 Location: Southern Italy
My System: Prodelin 11ft (335 cm) Windows 2000 XP |
Recently, 11556 V (62East) increased its power. Ever since the signal quality on my Golden Interstar 8005 receiver has been varying in the interval [49%, 58 %] (corresponding to [6.7 dB, 8.2 dB] on my Ro.v.e.r) better in the morning; the threshold is 40 dB (the fec being 3/4). During the morning and late afternoon 10980 V and 10.993 V are also watchable, but the signal strenght is much lower. The threshold for 10993 V is 35% its fec being 2/3. Another good test is Amos2 (middle-east beam) and 60East. My antenna is a Prodelin 3.35 cm. Coviello | ||
| | #30 | |||
| Regular Member Join Date: 01-01-2000
Hi Ralph.... we have got a SLINGBOX........ ![]() the quality depending from uplaod source.... 512 kbps is quiete good Ciao | |||
| | #31 | ||
| Member Join Date: 18-02-2007 Location: spain
My System: no dish | Hi Paul682,if you are(or speak) italian you should have a look at this post in an italian forum: _http://www.digital-forum.it/showthread.php?t=36076&highlight=la+verita%27+su+a stra+2d where someone from Umbria says he received good pictures on Astra 2D using a 2.4m fortec star. He also added some photos to prove it. | ||
| | #32 | |||
| Regular Member Join Date: 12-10-2006 Location: Fetihye S/w Turkey
My System: 3Mtr Laser PF invacom .3 lnb and laser feed horn AD3000VAICP Cards Cams all the other Stuff Annie 204 Spectrum |
| | #33 | ||
| Specialist Contributor Join Date: 28-05-2003 Location: Stuttgart (48.79N/9.19E)
My System: Kabel BW | Maybe it's the same sidelobe that covers also NW Greece. There also we have no sign of the Verticals on "small" 2.40m dishes. @Gaza_1: As i've seen you're using a LS3000 dish (Standard oder Super feedhorn ?) . I wasn't aware of these cheap dishes made in Turkey before. Could you write some words about their quality to have a comparison between them and the major players Channel Master, Andrew, Patriot, DH, Precision Antenna, Aerial Oy, Irte, Supral, Famaval,...? Of course in a new thread not to get too OT here.
__________________ I demand: Pay-TV subscriptions worldwide available - with any receiver - just like print magazines ! Free access for free citizens now ! | ||
| | #34 | ||
| Regular Member Join Date: 13-04-2005 Location: Belgium
My System: 3x Dreamboxes 13°, 19.2°, 23.5° & 28.5° East 7°, 8° West 2.4m Aerial Oy for Nilesat Subs: Canal+/Sat France, Premiere/arena, TV Vlaanderen | | ||
| The Following User Says Thank You to charly20 For This Useful Post: | deepbluesky (02-05-2008) |
| | #35 | ||
hi, we just got back from tweeking the 4 meter dish. first from 157 cm we got the focus right on to 154.5 cm and the overall signal did come up on the stronger signals. then we chacked the skew to see if its ok and its on as possible. then we moved the dish and we got the signal a little stronger. we looked at the hors low and vert low cables without going through the multi switch, we are using a gray invacom .3 db qtf-031 and this has all for ouptuts different hor-low,vert low,hors-high and vert high. nothing ![]() we even tried a small line amp just for gp knowing this would generate some noise in the system and we tried 3 different receivers and its no go for the naples lago patria areas. will have to find someone in the area of rome and see if we can see the dish set up and measure the signal with the EP 313 unaohm and see whats up. unless there is a magic feed horn other than the original IRTE feed for 4 meter dish that can make it work or a lnb with a .007 bd noise figure or we freeze it to -470 F noise figure is 0.00 db. have a good day ralph | ||
| | #36 | ||
My System: 3.7 MESH | I WAS yesterday more lucky with 83 east KU TATA SKY 100% on 12 transponders the only bad thing is all the channels almost 200 was encrypted in NDS ciao ***** astra 2d is more easy to get a sat distant over 6000 km than one distant 1000 km ciao | ||
| | #37 | ||
My System: 3.7 MESH | hy someone has suggest me to buy the quad invacom for get all the tp's on 2d bird yes i get all the tps some with a little pixelation on middle hours some with a clear image soon i send some photo and details of all the transponders with quality and signal P.GRANDICELLI WITH 3,7 FIBERGLASS DISH STRONG RECEIVER SRT 6155 QUAD INVACOM MONTELUPONE ( MC ) CENTRAL ITALY 43,34 North 13,55 East | ||
| The Following User Says Thank You to paul682 For This Useful Post: | barney (12-05-2008) |
| | #38 | |||
very good job Paul, i'm in Vasto (CH)and i have a 3.00 mt dish with feed/lnb Invacom quad but any signal from astra2d..... Do you think that we have a probability to get astra 2d here? Ciao Barney | |||
| | #40 | ||
My System: 3.7 MESH | im in the south limit of astra 2d with 3,7 m dish because i think that probably 50 km more south of my location dont arrive nothing because i am in the south limit of this bird for CENTRAL ITALY | ||
