No Channel 4
Thread Tools Display Modes
Old 26-04-2008   #1
My System: Pace 2600 receiver, Channelmaster 1.8 m, Channelmaster feedhorn, Invacom C120 twin LNB
Red face No Channel 4
Location Alviano Italy - I've eventually managed to get reception on Tp 24, 12168 V, 27.5, 2/3, quality 70% strength 70%, but only when the LNB skew is set at max i.e. -40 deg, rather than the recommended -16 deg. However I cannot get channel 4 no matter what. I get a multitude of channels not worth watching, including channel 5, some radio stations including Yorks radio, but no Radio 1,2, 3 or 4. Can anyone advise why the LNB skew is so far out, is it possibly because the azimuth and elevation are not correctly adjusted? If the latter then why do I get such good strength and quality? Any advice gratefully received.
Roddyb is offline   Reply With Quote
Old 07-05-2008   #2
My System: Pace D2600 SkyBox IRTE 2.4m dish (Distorted) CM 1.2m dish + Feedhorn Invacom C120 Quad LNB HD Home Theater System
Hi Rod
I live not too far away from you and have a 2.4m IRTE dish. I can only get Channel 4 during the day, with Channel 5, Radio 1,2,3,4 etc 24/7. However, I cannot get BBC1,2,3 etc.
I set my LNB orientation for maximum output on Channel 4 with a skew from horizontal of about 12-14 degrees. I do not know why your get the best signal at 40 degrees. What instrument did you use to set up the system?
PJG
pjgregory is offline   Reply With Quote
Old 13-05-2008   #3
PJG
Thanks for the response and apologies for my tardy reply. I've been in Italy and without internet access for the past 2 weeks. I used a Digisat Pro meter and a digital compass to set the system up. Initially I was getting no reception despite the signal strength and quality showing in excess of 60% and it was only whilst mucking around that I found channels at maximum LNB skew. I'm becoming suspicious that I'm either still on the wrong satellite or the LNB and feedhorn are mismatched. This is all new territory to me and it may just be down to total ineptitude on my part. I've tried playing around with the LNB position again without success and I am now back in the UK trawling the internet for further info. I find it strange that I can get all Ch 5 options, Yorkshire radio and various other crap channels, but no Channel 4 nor Radio 1, 2, 3 or 4. I also think I'm going to have to arrange internet acess in Italy so that I can get help/advice whilst actually playing around with the setup. Anyway thanks again for your response, I'll let you know if I eventually succeed.
Roddy
Old 13-05-2008   #4
My System: motorised Gibertini 125+ fixed dish 72 stabHH120 lnb Sharp 0.4 Fortec Passion HD QUALI IRCI HDTV Homecast PVR 300 Digiscrappybox some CAMs some subscriptions
Roddyb, you got to say wich dish size you are using, it's by far much more important than LNB skew
Aviano is eastern Italy so no surprise that you cannot easily get Astra2D channels, TP 12168V (Ch4 encrypted from freesatfromsky) is on Astra2A so obviously you can get it, TP 10729V (Ch4 fta from freesat) in on 2D
I suggest a 180 cm dish to get it
I'm very surprised pjgregory cannot get Astra2D (BBC, ITV, etc.) from there with a 2.4m IRTE dish, I have heard many reports from Friuli receiving all Astra2D channels with 180 cm dish...
danit is offline   Reply With Quote
Old 14-05-2008   #5
Hi All
Roddyb - from one of your other posts you say you have a CM 1.8m dish, Invacom C120 with CM feedhorn and Pace 2600C receiver. The Invacom C120 quad seems to be the best (see posts by SNAP) and the CM feedhorn is designed for the CM range of of dishes.
As I said, I get Channel 4 during the day, Radio 1,2,34, etc all day long. I know that my 2.4m dish is warped so I may be getting less gain than you are.
Dave Branson at Poggibonsi reports Astra 2D with a 1.9m IRTE prime focus dish. So we have
Poggibonsi 1.9m P/F 44db All OK
Montefollonico 2.4m P/F < 46db Channel 4 daytime + Radio
Alviano 1.8m P/F 45.5db No Channel 4 - No BBC Radio
Looking at the map, I am some 62Km SE of Dave, while you are about 133km away.
It is clear that we are at the edge of the fringe area so dishes about 2m are not really cutting it. I am currently looking at 3.2m or even 3.8m prime focus as the next step.
MODERATOR: - Is there anyway I can contact Dave Branson and Roddyb. I know I cannot post my email or telphone number and I cannot send private messages for a month. I would be quite happy to take my spectrum analyser over to them to get some measurements to find out what is really happening.
PJG
Old 14-05-2008   #6
Amo Amas Amant Admin
Topper's Avatar
Well
I am sure everyone appreciates you are being helpful unfortunately the rule has to be enforced owing to the PM system being abused previously. Why not fill out your Vcard then when anyone clicks on your profile they can contact you
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 15-05-2008   #7
Done That
Topper
I ave ticked the Vcard box so they should be able to download my e-mail address. Do I have to do anything else?
PJG
Old 15-05-2008   #8
JPG
How do I access your e-mail address? When I click on the profile it doesn't give any obvious (to me) info on the e-mail address. I am quite happy to make contact with you by e-mail now, or by phone when I return to Italy next week.
I've also ticked the Vcard box in my profile, so if you can find my e-mail address please get in touch.
Roddy
Old 15-05-2008   #9
rolfw's Avatar
Click on the username, go to user profile, then cl;ick on Contact info and then download vCard.
__________________
Rolf
Donate
Old 16-05-2008   #10
Hi Rolfw
I can see a tab marked "Contact Info" on your user profile, but not on mine or Roddyb's. How do you enable this tab. I have ticked the box maked Vcard.
PJG
Old 16-05-2008   #11
rolfw's Avatar
Strange, I've just looked and it was visible to me.
__________________
Rolf
Donate
Old 16-05-2008   #12
PJG
I was having the same problem with the Vcard info as yourself so I went in and ticked it again and now I can see the change when I select "contact info" in my details. You should now be able to get my e-mail address and contact me.
Roddy
Old 16-05-2008   #13
Hi Rolfw
I am sorry, but I still connot see a "Contact Info" tab on either Roddyb's or my profile. I have cleared the browser cache and then re-clicked on the Vard box in my profile. How come you can see my Vard, but I cannot?
PJG
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
