BBC & Setanta problem
Thread Tools Display Modes
Old 09-05-2008   #1
trigger's Avatar
My System: 30W,7W,13E,16E,19E & 28E Dishes everywhere Darkbox 2008HD Sly+ V3
Here in Lanzarote we can receive Setanta sports (and others on 12560H)on a 1.2M dish no problem. To get BBC ITV a 3M is required. I have installed 80+ 3M dishes no problem. Recently I have 4 customers that are having problems with Setanta on the big dish either breaking up or showing no signal. Although the dish is peaked at 2D there should be more than sufficient signal off Eurobird fixed to recieve Setanta etc. I have changed LNB´s without success.
If thie dishes were bent then BBC/ITV would suffer but they are ok so I´m assuming they are ok
I need some inspiration please
trigger is offline   Reply With Quote
Old 09-05-2008   #2
koansrc's Avatar
My System: CM 3.0m @ 28.2 w PACE
Also having problems for the past maybe month or so to get ALL the Eurobird channels (3m in Athens) when tuned to 2A. I've noted sufficient signal for the EU TPs but no quality. For example Information TV suffers the max although I can't remember which beam it's on. I thought I was getting better at peaking the dish on astra, hence loosing eurobird ( skew must be different for astra and eub (although opinions vary on this in related threads) ). I think it's also the "bigger the dish the narrower the beam (or something like that)" theory too.
FWIW
koansrc is offline   Reply With Quote
Old 10-05-2008   #3
My System: None Yet
Astra 2D in Fuerteventura
Trigger are you able to supply and install a 3.1M dish in Fuerteventura? If so how can I contact you?
stringinteger is offline   Reply With Quote
Old 10-05-2008   #4
trigger's Avatar
Postmail me with details of where you are so I can work a price out
Old 11-05-2008   #5
My System: None Yet
trigger I am in Playa Santa Ines, shown on some maps as Aguas Verdes on the West Coast of Fuerteventura more or less opposite Rosario.
you can email me on REMOVED (What do you mean by postmail?)
Enable your Vcard.
Old 13-05-2008   #6
My System: None Yet
Vcard is now enabled. Thanks
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
