Help to get free channels in Dusseldorf | |
| Member Join Date: 09-05-2008 Location: Dusseldorf
My System: Panasonic Reciever |
Hello I am new to all of this, I am working in Mulheim in Germany (15 Km's north of Dusseldorf). I have purchased a Panasonic satellite reciever from Ebay I need to line my dish up to the Astra 2 satellite beam for BBC1,BBC2,ITV etc (free channels), I think....? My problems are:- 1)Does anyone know the compass bearing or direction that I need to set my satellite dish too and also the angle that I need my dish on? 2)Will a 80CM dish be capable of fixing onto the signal? 3)Will a general LNB be okay to use? Any help would be greatly appreciated. Regards Finbar | ||
My System: Technomate TM1000D Receiver. Stab H-H90 motorised Triax TD110 dish 42E to 30W. Inverto Silvertech 0.2 LNBF. Fortec.star 90cm fixed on 26E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox | Hi Finbar, Welcome to satellites, There are a few online calculators that give you the correct angles to use. Here is one:- _www.dishpointer.com. Heres the footprint for Astra 2D http://www.lyngsat-maps.com/maps/astra2d.html You should easily get it with an 80cm you are inside the footprint. ![]() Yes, any Universal LNB will work, no special LNB is needed. Robbo ![]() P.S. Merged your two posts into the same thread.
__________________ Last edited by Robbo71; 09-05-2008 at 11:03 PM. | ||
| | #5 | ||
My System: Panasonic Reciever | On the dishpointer website, for the Astra 2a-b-d satellites,it states that the Elevation is 27.8 degrees and the Azimuth (true) is 153.5.....? What is Azimuth, is that a compass bearing. Told you that I was new to all of this? Help!!!! Finbar | ||
| | #6 | ||
| Specialist Contributor Join Date: 22-06-2005 Location: UK: Kent. Spain: Madrid.
My System: Sky Plus V3 TDS 470n, Pace 2600CI, Thomson Sky HD, Technomate 1000D, Prodelin 1.8m dish + Invacom Quad C120, CM feed, Lacuna/Wolsey V3 meter | Azimuth is the horizontal bearing from north. Take away 153 from 180 and you get the bearing from due south, that is 27 degrees east of south. er..they could of course just have said point the dish south-east, it's a lot easier. | ||
| | #7 | ||
| The Consumate Dreamer Join Date: 01-01-2000 Location: Somewhere where the Sauer is Kraut and the Wurst is Brat
My System: I bet on red. If I lose, I double the bet on red again. I continue with this until I lost everything. ![]() Muhuhuhahahahahaaaaarrrgggh | If you can see a "normal" german dish, they point to 19 east. So you will have to move your dish 9 degrees to the "left" when standing BEHIND the dish, and one degree lower. If you can get the TV near the dish so you can watch the signal strentgh while you move the dish it should be a piece of cake. Just move it by small steps at a time. 80 cm in Düsseldorf should be ok, but you are on the limit. A larger dish would be better, but try it out first.
__________________ I only believe stuff that comes straight from Mr. Horses mouthHelp build Satellites City! Help build the Satellites MiniCity - no downloads, no money involved, just a daily click onto the site. More details here: http://www.satellites.co.uk/satellite/717922-post1.html | ||
| | #8 | ||
My System: Technomate TM1000D Receiver. Stab H-H90 motorised Triax TD110 dish 42E to 30W. Inverto Silvertech 0.2 LNBF. Fortec.star 90cm fixed on 26E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox | And if you zoom in really close on the google map on dishpointer, and put the red marker where the dish is going, the blue line shows you which way the dish should point. ![]()
__________________ | ||
