Where do I find a large feed horn? | |
| Member Join Date: 06-05-2008 Location: Montepulciano, Italy
My System: Pace D2600 SkyBox IRTE 2.4m dish (Distorted) CM 1.2m dish + Feedhorn Invacom C120 Quad LNB HD Home Theater System | Hi Iceman and bignick (amoung others) have mentioned using a largefeed horn for large prime focus dishes combined with the Invacom C120 quad LNB. bignick posted comparison photographs on a thread about a year ago on Channel 4 reception. It would seem that these feedhorns are common in Cyprus, but I cannot find a supplier on a Google search. I already have a 2.4m dish and am looking at buying a 3.7m replacement so it may just give me the odd fraction of a db improvement that I need for Astra 2D. Can anyone give me some more information please? PJG | ||
| Regular Member Join Date: 08-01-2007 Location: italy
My System: 3.7 MESH | hy my friend ask to coviello that buy this feed from them but in your case i dont think that is an illuminator problem you can gain something with that feed but you need more gain from the dish that your 2.40 probably dont give to you the fact that in UMBRIA someone can get 2D with 1,8 m iis so strange because i am 70 km more east of UMBRIA and i need 3,7 meter or is a strange sidelobe from the sat or is impossible that 70 km more east the satellite give the double of power u know!!!!! ![]() ciao | ||
| | #4 | |||
| Specialist Contributor Join Date: 13-02-2005 Location: near Limassol, Cyprus
My System: 3.1m Famaval on 28.2, 1.5m offset on 19.2e, 13e & 7e all mixed in a spaghetti of wires and going into a dream thingy. |
Future Sat. e-mail futuresat at cytanet.com.cy Now that they have the euro it might be quite easy for them to send one to you. They are called the Large Adjustable Feedhorn. I would perhaps advise that you ask for the "Famaval feedhorn holder" that it fits into as well, just in case the one with your dish isn't compatable. They speak English pretty well. Cheers Nick | |||
