Dish size costa blanca | |
| Member Join Date: 27-08-2008 Location: essex/costa blanca
My System: 90cm technomate 1500 essex uk/ 1mt pace digibox playa flamenca costa blanca |
hi have seen in a add in spain a 1.3 5 portegese high gain dish, suppose to pick up bbc, itv most of the day, has any one heard about it and the spec , or what is the best performance dish up to 1,35 im using pace digibox, and a .2 lnb on a 1mt dish at the moment, i get the channel five , true movies sky news ect, no bbc, itv im in playa flamenca thanks | ||
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Welcome to satellites forum, To receive the Astra 2d UK spot beam (BBC, Channel 4 & ITV), in your region you'll most likely be better off with a 2.4M dish for reliable reception although some areas close by appear to pull this beam in with a smaller dish ie.1.8M North, South and Eurobird beams can be received with a 90cm - 1.2M See coverage map for 2d _http://www.lyngsat-maps.com/maps/astra2d.html
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - Last edited by satelliteman; 27-08-2008 at 10:26 PM | ||
| Regular Member Join Date: 05-04-2008 Location: Gandia, Spain
My System: 1.8m Famaval PF Dish, Pace 3100, 2600, 430, freesat Humax HD, Freesat Grundig, 0.8m illusion motor, Dreambox DM7025 | a 1.35 can limit reception of channels at certain times of the day - so you can go for this smaller dish if you can live with not having certain channels (like bc2 and c4) on a 24./7 basis. - as you say "most of the day" - make sure it is not when you will be wanting to watch those channels generally the minimum requirement is a 1,8... in areas around benidorm a 2.4 is recommended, | ||
ok thanks, looks like the add in costa blanca times about the 1.35 dish is dreaming, it did not state the db of the so called high perf dish, it looks like i will have to stick with the 1 mt, has i have not got the room for a 1,8. would the new freesat box perform any better, i no there are both still using the same sat thanks again | ||
| | #5 | ||
My System: 90cm technomate 1500 essex uk/ 1mt pace digibox playa flamenca costa blanca | sorry worbany, just read your reply, yes some itv or bbc would be a bonus, does any one no the best dish up to about 1.35 | ||
| | #7 | |||
| Member Join Date: 05-05-2005 Location: javea in costablanca
My System: Motorized Gibertini OP150 | costa blanca for you m8 look here---> http://www.satellites.co.uk/satellite/775393-post9.html cheers | |||
