My TV Screen has gone green
Thread Tools Display Modes
Old 24-08-2004   #1
Hi all. Can anyone help with my tv screen problem. I have Sky TV (digital) and when i switched on the TV i see a green screen. The picture is there and sound and all the functions work properly but its green. We had some heavy rain this afternoon and i think its been since then. I am not technical so i was hoping someone could shed some light on it for me. My warantee cover has run out from sky now so i am hoping its going to be simple to fix.
thanks in advance
ezz
ezzkazz is offline   Reply With Quote
Old 24-08-2004   #2
BGonaSTICK's Avatar
Sounds to me like your telly has gone west.... is it only on SKY, or analogue TV as well?
__________________
Old 24-08-2004   #3
I dont actually have a normal tv ariel plugged in, i just run off of the satellite. I am confused because when i put it on the menu screen its ok (blue) the colours it should be but as soon as you select the channel and it goes to it you can see the acual picture ok but its in green
Old 24-08-2004   #4
rolfw's Avatar
Try a different scart lead, or at least check the connection of the one you have. Also try changing the output from RGB to PAL composite, or vice versa.
__________________
Rolf
Donate
Old 25-08-2004   #5
Talking
thanks for your suggestions. Believe it or not i though i would try the obvious and switch it all off to reset it and its worked thank god. It goes to show it can be a simple thing. Problem solved
Forum Jump
Similar Threads
HDTV Primer spiney High Definition Receivers transmissions, satellite and Terrestrial 0 16-01-2006 12:42 PM
Techomate 5500dapci green screen Moschino Digital systems 2 22-03-2004 12:20 PM
Channel 4 to screen 'teen sex drama' net1 The Meeting Place 0 06-11-2003 07:56 PM
Screen legend dies net1 The Meeting Place 0 01-09-2003 09:56 AM
Sky News bring back on screen ticker net1 B Sky B Digital and 28.2 East General 0 13-08-2003 08:26 PM
