How to fit a pole in deepfreeze conditions? | |
| Regular Member Join Date: 01-01-2000 Location: Borlänge 200km WNW of Stockholm
Hi everybody I live in Dalarna in Sweden with a frost-free depth of 150cm. I am going to fit a Gibertini 150cm dish on a pole in the garden. My supplier have recommended a concrete block with a the size 120x120 and 60 cm deep and put the concrete base on frigolit to prevent it from warping because of the frost going under the concrete. Has anybody here any advice to such a "contraption"?
__________________ Cheers Huffin the Puffin | ||
| Specialist Contributor Join Date: 03-04-2003 Location: Kyrenia - NORTH CYPRUS
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD | 120x120 and 60 cm deep sounds to me like a lot of concrete for a 120cm dish.. | ||
| | #3 | |||
__________________ Cheers Huffin the Puffin | |||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Agree with Iceman, does seem a lot for that dish, having said that, if you are happy to dig and fill a hole of that size, then the dish certainly won't move. ![]() Frigolit would appear to be a very dense form of polystyrene insulation http://www.frigolitfabriken.se/eng/index.html I guess that any similarly dense product would suffice.
__________________ | |||
| | #5 | |||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Well I guess that it will depend on the exposed nature of the location, but I would have thought that a 90 or 100cm square with that depth would be more then enough. Having said that, if that is what the local guy recommends, then perhaps it would be the sensible course to follow his advice, it would certainly provide some future proofing. ![]() Is he recommending a buried mast or bolting a stand onto the base?
| | #7 | |||
| Specialist Contributor Join Date: 13-02-2005 Location: near Limassol, Cyprus
My System: 3.1m Famaval on 28.2, 1.5m offset on 19.2e, 13e & 7e all mixed in a spaghetti of wires and going into a dream thingy. | Thats about the size I recommend for 3m dish out here in Cyprus! How windy does it get over there?
| | #8 | |||
If we get a storm from the west - it will have lost a lot of the power passing the norwegian mountains. There will be no risk of a storm hitting the dish from the front as that part of the garden is protected.
| | #9 | |||
| Member Join Date: 06-06-2003
| | #10 | ||
My System: 3.0m Motorised Channel Master 4 fixed dish SKY_HD DM7020s Vsat Kathrein UFS-910 HD | thx for the explenation PGH....excessive use of concrete & polystyrene makes sense after your post... | ||
| | #11 | ||
| Regular Member Join Date: 09-05-2003 Location: gothenburg
| well this should give you something to do on sunday morning or give good old Martin effing Timmel a call ... My suggestion would be to fix it to any granit / rock if you have any available in the garden or a bit under the surface , then you'll get a sound base . you'll probably still get some movement at only 60cm deep , put 2 layers of 10cm frigolit under and a layer round the edges . I also think 120 by 120 is overkill , but it gives u something to do this autumn ! Now my problems the forrest all around me , thats more than a weeks work . | ||
| | #12 | ||
| ryan Join Date: 16-11-2004 Location: Almeria spain
My System: pace 430 gibertini 1.25 | i have fitted a lot of gibertini 1.25 dishes in spain we have the opposite problem dry ground like concrete but when wet it turns to mush,i usualy dig a hole as deep as possible min 1 meter but small in diameter 50cm square like a pile drive and the ground is more stable the deeper you go and the frost wont go down as far .a platform as you say will tilt under certain conditions . | ||
Similar Threads | ||||
| Pole diameter | jleal | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 7 | 06-08-2006 02:06 AM |
| Pole advice | gameboy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 19 | 12-10-2004 01:45 AM |
| Getting the pole straight | martinw01908 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 6 | 13-05-2004 12:21 AM |
| diseqc 1.2 motor for 75mm pole | razdaz100 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 6 | 28-02-2002 04:37 PM |
