phased arrays | |
| Guest
Posts: n/a
Does anyone have enough knowledge of microwave and waveguide technology to comment on the following? I have 2 dishes with C120 mount LNBs. A waveguide could be taken from one of the C120 mount feeds to the other feed where it would be combined using some sort of orthomode transformer in reverse. If the signal in the waveguide had an adjustable delay then the combined signal would be enhanced at a particular frequency (ie 10773) as if the 2 dish areas had been added together. I presume that this arrangement would be some sort of phased array. Would it work ? Geoff | ||
| Specialist Contributor Join Date: 06-06-2003 Location: Famagusta District, Cyprus
My System: Famaval 2.4m dish, Invacom 0.2dB LNB (single), Pace 430N |
Great minds think alike, same name (Geoff) too. I am working on receiving Astra 2D in Cyprus, but without buying for CYP3K a 3.8m dish. We Radio Amateurs used to stack arrays (aerials) linked by a phasing harness. This way 2 or more SMALL aerials give the same result as one megasize one. This can be done with Satellite dishes, say 2 x 1.8m, giving an equivalent size of a 3.4m (note not quite double size). The problem with Sat dishes is the LNBs - the Local Oscillators would have to be in synch. In theory this could be done by disabling the 2 LOs in the 2 LNBs (or 4, or 6, however many dishes stacked) and feeding them the output of a third (spare - not active on a dish) LNB's LO. However it appears on first look at this that the usual LNBs on the market do not lend themselves to such mods. If this COULD be done, however, we could all pull in fringe signals at a fraction of the costs!! I also investigating another way - more when I have it. I want my BBC + ITV channels (now on 2D) back, but without the massive expense of a huge dish - not to mention the fact a huge dish is unwieldy and subject to storm damage much more than small dishes. Comments/ideas/innovations invited Regards Geoff Smith Vrysoulles Famagausta District Rep. of Cyprus | ||
| Honorary Admin Join Date: 01-01-1999 Location: Cloud Cuckoo Land
| Theoretically it is possible. But it's difficult as there is always some interference, since the signal arrives at each dish at a slightly different instant in time. In fact, the phase interference that results provides information that can be used to determine stellar distances (for example) and that whole field is called interferometry. The combination of signals from several smaller dishes to "mimic" the resolution of a larger dish is achieved via computer processing. SETI (Search for Extra-Terrestrial Intelligence) was planning to use a phased array of small satellite-TV dishes to mimic a large radio dish. See here: http://www.setileague.org/array2k/ 2old | ||
Correct, in theory. In practice in our (Cyprus my location) case there is no practical problem as the difference in distance between 2D and our two dishes is miniscule, plus the fact the signal strength, or Sig to Noise ratio, is receivable OK. With say two dishes you have to combine the outputs into the single feedline to the Sat receiver. For this a phasing harness is used and it is very easy to construct using the right type of feeder. I won't go into detail now - but it is easy. One thing the phasing harness does is ensure the impedance remains at 75 Ohm, we required by the receiver and to avoid standing waves. As I said in my first message on this subject the ONLY problem is getting the 2 LNB Local Oscillators (LOs) synchronised. This is purely a practical problem with the hardware currently on the market - I not sure it can be done, but maybe some other contributor can suggest ways? I'm sat here with a Panasonic 30 SKY receiver and no pics! Missing Cora and Eastenders etc as much as the other half. There has to be a technically workable solution as an alternative tp mega-size mega-expensive dishes, we just got to get our heads together to find it. Stacked/Phased-feedline dishes are one obvious option to investigate further, if nowt else to keep the bank manager at arm's lenghth! Cheers Geoff Cyprus | ||
| | #5 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Old Satellite posted some information on PLL LNBs, I believe that the phase lock loop technology enables very accurate frequency control.
__________________ | |||
| | #6 | ||
| Regular Member Join Date: 31-05-2003 Location: Alexandria, Egypt
| Geoff I'm relatively new at this game - I have picked up most of the 2A/2B signals now in Alexandria on a 2.4m dish (still waiting for the SKY card to check the quality though) - however I get a "no signal" message for the 2D channels. For this stacking system to work I'd guess that you'd need to pick up some of the signal - how do you know if you're getting a sufiicient amount of signal to allow the stacking to work. I'm very interested in your idea - I've just found a 3.7m dish locally made - but really don't fancy putting it up (expense & high winds + local concrete could = no roof - that wouldn't go down well with Mrs richardinalex Cheers Richard | ||
| | #7 | ||
Well of course there must be signal there (from 2D say) in the first place or no dish will pick it up and lock-on. In Alex, as here in Cyprus, the signal is there alright but in noise of course. A large dish merely increases the signal to noise ratio sufficiently to get a picture. Using 2 smaller dishes connected electrically with a phasing harness makes the combination 'look' like a large dish electrically. The phasing harness has to be AFTER the freq down conversion of course, which is why at the satellite's transmit freq both LNBs MUST convert down to give the exact same down-converted freq; to achieve that both LNBs must have oscillators running at exact the same freq. So f1-f2 are same in both cases. The theory I am 99.99% sure is sound. The practicalities are my problem since to buy locally all the hardware I need to experiment would bust the household budget! And her indoors' patience, I learnt a long time ago that is unwise. More on this topic soon I hope, I have a friend of mine in UK with BBC's Engineering Dept working on this - he owes me a favour from 40 years ago which he had forgotten about. Geoff | ||
| | #8 | ||
| Guest
Posts: n/a
| Many thanks for the reponses - but I think that you are all missing my point What I am proposing is to combine the signals before they reach any LNB. I do not think that combining the LNB outputs - even when phased locked would give more than marginal improvement. My idea would need some sort of low loss flexible waveguide operating at 11Ghz with some way of adjusting the waveguide length to phase match the signals - this bit could be done by some sort of tube sliding within a tube arrangement. Do low loss flexible 11Ghz wabeguides exist ? Geoff P.S. for Alexinalexandria - the dishes are already lined up on Astra 2A and B | ||
| | #10 | |||
| Member Join Date: 02-06-2003 Location: Cyprus
It could be cemented into a brick plinth to stop it becoming a frisbee. Regards Derek | |||
| | #11 | |||
to be metallic coated. Would be best constructed in one of those little workshops in Limassol or similar premises. Geoff | |||
| | #12 | |||
Derek | |||
| | #13 | ||
| Guest
Posts: n/a
| I have no experience with these, but Swedish Microwave sells PLL LNBs that will lock to an external 10 MHz reference. See http://www.smw.se/products/pll10ref.htm These might provide down conversion to the same L-Band frequency from two dishes (for combining). You might contact Swedish Microwave direct to see if they have other options. I am in Northern Greece and would very much like to receive the BBC FTA signals from Astra 2D. Regards, Gary | ||
| | #14 | ||
| Specialist Contributor Join Date: 28-05-2003 Location: Stuttgart (48.79N/9.19E)
My System: Kabel BW | Hello everybody This is a very interesting topic you are talking about here. I remember around 10years ago in analogue times that in the Tele Satellite International Magazine an experiment was published about receiving US-satellites in Venezuela which would need a 20m dish approximately. They achieved this with 8 5m dishes finally. I really have no idea if this is also possible with MPEG2 signals but why shouldn't it be ? @gwise: There is someone in Kastoria (40.6N/21.3E) who gets the BBC and most of the hor. Transponders of 2D almost all day. The dish is a 2.40m motorised and with C/KU-Feed, so effectively you can compare it with a 2.20m. Maybe some kms further away the situation is harder and you might need a much bigger dish but if you are in N-Greece i would advise you to call Emo system communication in Katerini (Komvos Korinou just on the old road to Thessaloniki). I talked lots of years ago (1995) with them when they had their store inside Katerini and they had installed many bigger dishes (mostly for Astra 1) all around Greece so maybe they are informed about the Astra 2D in different locations in N-GR. Here's their mail: emo@otenet.gr What an irony, i am inside the 2D footprint in Stuttgart Germany but the wall is between my balcony and the southern hemisphere. Hope i could help a little. Please keep on searching for a solution with the phase arrays. There are so many weak satellites and if these could be received with this method this would cause a revolution in the market )cu ![]() | ||
| | #15 | ||
| 2 x 1.8m, giving an equivalent size of a 3.4m (note not quite double size). 2 x 1.8m dishes would have the equivalent area of a single 2.5m if there are no other losses involved, so the complexity of combining will not be offset by the increase in signal from the phased array Good in thory but a pipe dream in practice
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #16 | ||
| Guest
Posts: n/a
| Many thanks for your response - there is obviously nothing new under the sun ! Do you remember anything as to how the output from the dishes was combined - if whatever was done worked on analogue signals there is no reason why it should not work on the present digital signal. So far as implimenting the idea is concerned I have found that there is no problem getting flexible waveguides to convey the 10.7 Ghz signal between the dishes but the only adjustable delay line system I have found so far is a digital box costing about $2000. Geoffrey | ||
| | #17 | ||
My System: Kabel BW | Ok finally i have found the article about receiving a US-Satellite in Venezuela. It's published by Christian Mass (Chief-Editor of Tele Satellite International) in 9/1993 p.178/179 (in german) 19 dBW had to be received then from G-Star 93.5W DH Satellite from Wisconsin made the job. They set up 8 5m dishes. Each antenna was aligned with a spectrum analyser to a max. of signal. Then the 2nd dish was connected with the first and in right phase. Unfortunately it isn't described what they did exactly. But with 8 5m dishes the signal was still too weak, didn'T reach even the FM treshold. So another 8 5m dishes were installed. Then it was ok. So they avoided the not possible installation of a 40m (!!!) dish. After that they tried the same in Wisconsin. But Brazilsat could not be received because strong signals from the neighbour satellite Spacenet (4° close to Brazilsat) made the reception of the wished sat impossible. Ok this all only for C-Band. Upon that time they hadn't had any luck for KU-frequencies. Since then i don't remember any article i have found for this. I would advise to contact Christian Mass. As mentioned in the new issue of TSI he will travel in winter to Southern Brazil where Klaus Schumacher has built up his own 8m dish for receiving Astra 19.2 analogue and the Hotbirds on 13E also only analogue. Maybe he knows more about it. Here's his mail: drdish@drdish.com P.S.: Maybe also in Namibia/South-Africa could be anyone who tried this since as far as i remember around 95-97 there was someone receiving Astra 19.2 analogue with a 12m dish. Chris | ||
| | #18 | ||
| Specialist Contributor Join Date: 01-01-2000 Location: pj::
My System: Dreambox 7000S + motorised 80cm dish, Amstrad DRX550 Digibox + fixed dish | Perhaps it's possible to combine the bit streams from several receivers (each with their own dish and LNB) after demodulation but before error correction. This would avoid the phasing problem from different LNBs. Some sort of logic that looks at several streams and decides whether a bit is a 1 or 0 by majority voting would output a single stream for error correction and channel decoding.
__________________ pc:: | ||
| | #19 | ||
| Unfotunatley the error correction of the two streams has no 'majority' vote it can rely on (the Space Shuttle has three computers for this purpose) Anyhow the reasons for relying on a sinple QPSK system leaves the need for a more robust method of transporting data by digital packets wide open. It works for low signals with little error in the first place. Once the problem with fringe reception crops up QPSK falls over quickly
| | #20 | ||
| Dazed and Confused Mod Join Date: 28-06-2003 Location: Wirral, NW England
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100 | Quote... Perhaps it's possible to combine the bit streams from several receivers (each with their own dish and LNB) after demodulation but before error correction. This would avoid the phasing problem from different LNBs. Some sort of logic that looks at several streams and decides whether a bit is a 1 or 0 by majority voting would output a single stream for error correction and channel decoding. I don't think this would work as you would only get a bit stream if you had enough signal to start with, ie a big dish or phased arrays first. PaulR | ||
Similar Threads | ||||
| Dish Arrays | Simba27 | Einstein's Alcove | 5 | 03-09-2004 02:30 PM |
