1M dish enough in north germany? | |
| Long Term Contributor Join Date: 01-01-2000 Location: Sunny old Bristol
My System: Pace Ver.3 SKY+ box 1,20m Dish Quad Invacom 0, 3db LNB P4 3,4 ghz 1024mb RAM Geforce 256mb 6800 Ultra |
Hi, my house is nearing completion so its about time I started sniffing round for a dish and lnb. Going by other threads i've decided on the Invacom 0.3db quad. Has to be a quad as I want to run a SKY+ and standard SKY box from it.I live in north germany between Husum and Flensburg just before the danish border. Had previously been using an 80cm dish with a universal cheapy lnb. Since BBC changed I rarely get it. Mainly evenings depending on weather. I have now decided on a 1M dish. What do you think ? Should be sufficient for my area or? Thanks, Methos. | ||
| Regular Member Join Date: 13-03-2003 Location: right next to the big dish
My System: Channel Master 1.8m, Lenson Heat 80cm triple feed 13° 19° & 28°, Triax TD110 with Jeager SuperJack, sky+ Pace v2, Panasonic TU-DSB20, Humax 5400, no name FTA and heap of old analogue receivers | Puffin what is the source of this footprint map? | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | You can see the large version of the map by clicking on it, the source of the information is actual dish setups, much of which has probably come from posts here and Expat's Astra 2D site see his signature.
__________________ | |||
| | #5 | ||
My System: Pace Ver.3 SKY+ box 1,20m Dish Quad Invacom 0, 3db LNB P4 3,4 ghz 1024mb RAM Geforce 256mb 6800 Ultra | So, i've gone for a 1,20 offset dish and the invacom 0,3db quad lnb with switch. I can get the invacom for E80 incl. postage here in Germany. Is this price ok? Thanks, Methos. | ||
| | #6 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | That sounds reasonable Methos, that's pretty close to what I pay wholesale over here.
| | #7 | |||
So should be able to see BBC again soon as long as those half dead builders get their arses into gear.Methos. | |||
Similar Threads | ||||
| Mr not work with North America Nagravision? | weagle | Matrix Reloaded, Revolutions and CAS interface | 3 | 16-07-2004 06:43 PM |
| TCM and Cartoon enter to Germany | net1 | Daily Satellite and Broadcast industry News | 0 | 26-01-2004 02:09 PM |
| Germany renews protest over Hitler wine labels | net1 | The Meeting Place | 1 | 05-09-2003 09:45 PM |
| Astra 2A North Beam in Central Italy | denis1501 | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 8 | 10-07-2003 11:56 PM |
| Astra 2A North Beam | gcohen | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 2 | 26-06-2003 08:22 AM |
