2.4 meter dish manufacturers in Europe | |
| Member Join Date: 07-06-2003
does anybody know the names or urls of any large dish manufacturers in europe or eastern europe! I am looking for a similar spec to the channel master, but at a reduced cost. so far I have only found irte, but there must be more! any help would be welcome onpiste | ||
| | #2 | |||
| EUROPEAN CHAMPIONS x5 Join Date: 18-07-2003 Location: Hässleholm,South Sweden
My System: System1.. Channel Master 1.8m with CM Feedhorn AZ/EL Mount. MTI AP82-TW 0.6dB LNB. Panasonic TU.DSB30 Decoder. System2.. 0.8m dish, 4 Digistar LNBS, Nokia 9802S Decoder. |
Channel Master is manufactured in the US, and therefore is 'quality' and has an extremely good gain for the relative size of dish. I have recently looked at IRTE, and its a good dish, but you have to buy a 2.4m to match the CM1.8m. Unfortunately the size is far more greater, and personally I think its huge! Then you have to work out the shipping costs of these large dishes, and that is another large cost. There are others such as in Poland ect. Vistit the link http://www.astra2d.co.uk/ and go into there links and manufacturers. There is one there and its reasonably priced, but I think its manufactured in Poland. Other manufacturers maybe SVEC (China mainly Cband), Televes (Spain), Gilbertini, ect. Generally CM are excellent, but getting the same spec for a cheaper price with the same size dish is problematic. If there is a manufacturer out there who does comply, I would like to know. Hope I was of some help! Maybe not...! | |||
| Specialist Contributor Join Date: 28-05-2003 Location: Stuttgart (48.79N/9.19E)
My System: Kabel BW | Comparable quality to Channel Master should be the following ones: Patriot, Andrew, MWO, DH Hope i haven't forgotten any producer but since these are used mainly by professionals don't expect low prices. | ||
| | #5 | |||
Well investigation has found three new companies Supral, Laminas and Hollstar. the supral is a single piece of alluminuim, and the others are 2 part vertical composite ones like channel master. I am investigating the performance of these, so if anybody has experience I would like to know any helpful information | |||
| | #6 | ||
| http://www.tripointglobal.com/Antenn...heets/24ro.pdf US made again , but in stores in the UK and in Germany, for less than the CM units. Three piece fibreglass so very resilient to weather, corrosion and other problems
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| | #7 | ||
| Member Join Date: 17-08-2003
| for a 2.4 dish in the Costa Blanca region of spain, try here >>> http://www.ciberland.com/indice2.htm Quite well priced at 850 Euro | ||
| | #8 | ||
| Member Join Date: 28-05-2004 Location: South-east of Poland
| There is Laminas in Poland www.laminas.com.pl They manufacture the dishes 1.0 to 2.4 m offset. Material GRP . In a few weeks they start with new 2.7 offset. | ||
Similar Threads | ||||
| Viasat Explorer to launch in Eastern Europe | net1 | Daily Satellite and Broadcast industry News | 1 | 03-08-2005 07:26 PM |
| Formula 1 from Melbourne to Europe | net1 | Daily Satellite and Broadcast industry News | 0 | 04-03-2004 07:43 PM |
| sat meter | lexden | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 28-01-2004 01:11 AM |
| Freeview manufacturers may not support 7-day EPG | net1 | Terrestrial Television, Digital and Analogue | 0 | 23-01-2004 08:43 PM |
| Five Is Fta All Over Europe!!! | makis23 | B Sky B Digital and 28.2 East General | 7 | 08-08-2003 08:14 PM |
