complete noob question, sorry !
Thread Tools Display Modes
Old 16-09-2003   #1
Hello !
I have a simple technical question with my sky digital set-up at home and this looked the it had enough people who could answer it
All the channels are fine with the exception of about 20 or so which when there is a lot of "white" on the screen I get loads of digital break-up (high pitched noises on the sound + squares of unrefreshed screen etc, I am sure you know what I mean).
The "System set-up" screen shows me at Full signal strength and almost full (all but one chuink) signal quality.
Is it my LNB or the Set Top box ? Is this a common fault with Panasonic boxes ?
So many questions so few answers......My installation company want £45 to come out and "have a look" and then god knows what else they'll charge.
Any help is appreciated,
Ellis Dixon
Ellis Dixon is offline   Reply With Quote
Old 16-09-2003   #2
Old Fred
Posts: n/a
Your signal readings are unusually high. I'm wondering if your dish is too large. Where are you and what is the dish size/type?
Fred
Old 16-09-2003   #3
rolfw's Avatar
Certainly sounds like a possibility, which channels in particular are causing problems?
__________________
Rolf
Donate
Old 16-09-2003   #4
Fred
Thanks for the reply.
To be honest I haven't got a clue as I have never seen it ! It's not accesible without a BIG ladder and lack of a fear of heights, neither of which I possess. When it went up it looked like one of the normal ones that they slap on the side of your house.
I live right on the South Coast England, Brighton to be exact.
To answer someone elses question :
Sky One is a particular problem all of a sudden, but none of the other "main" channels. Men & Motors, lots of the crappy teleshopping and cheapo channels seem to be the worst affected.
If the dish is too large would slapping an attenuator between the LNB and STB do any good ?
Ellis
Old 20-09-2003   #5
rolfw's Avatar
From what you say Ellis, an attenuator is unlikely to improve things, go into the installer's menu Services/System Setup/0,1,select/ Manual Tuning, then type in:
12285 V
SR 27500
FEC 2/3
This will then show you the actual signal strength and quality for that transponder.
__________________
Rolf
Donate
Old 21-09-2003   #6
12285 V
SR 27500
FEC 2/3
Rolf,
Thanks so much for your time, it IS apprexiated.
Okay, did as you said and then selected "find channel". Singal strength was shown as one chunk below max as was the Signal Quality.
What's the diagnosis doc ? ;-)
Thanks,
Ellis
Old 21-09-2003   #7
rolfw's Avatar
Well it certainly shouldn't be causing signal breakup with those readings Ellis, but perhaps you may get a better result with slight attenuation. Problem is that not everyone stocks the right type of attenuators, so if you can't find one, you could probably get away with using a two way splitter instead, it needs to have DC pass obviously and cover the full IF range, but it will have a 4 or 5 db insertion loss and might just be enough to cure the problem.
Still suprised though that any standard sized dish (45 to 85cm) would provide too much signal.
__________________
Rolf
Donate
Old 21-09-2003   #8
rolfw's Avatar
PS. Shame you can't borrow someone else's receiver to check if the same problems occur.
__________________
Rolf
Donate
Old 21-09-2003   #9
Rolfw,
Actually my girlfriend has exactly the same receiver as myself, I could easily borrow that to test ! Cunning Plan.
I'll report back next weekend. Thanks for the info on attenuators, i'll bear it in my mind if her receiver gives me the same results.....
Ellis
Forum Jump
Similar Threads
MM software version question geokar Magic Module 3 27-02-2004 12:51 PM
A question about feeds. Shahid Transponders & channels 2 26-08-2003 01:36 PM
Question Mark Fardelli Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 1 18-08-2003 11:00 AM
Yet another newbie question!! arraknid Satellite PC Card Systems & Internet by Satellite 5 03-08-2003 08:21 PM
Small Question about recieiver fruitbat Digital systems 3 10-07-2003 08:10 PM
