Euro1080 test transmissions | |
| Guest
Posts: n/a
Has anyone at the fringe been able to recieve the test transmissions for the HDTV service which is supposed to be on Astra 1H at 19E at 12.168Mhz Vertical, 27.5 and 3/4. I can just about get Vox from Astra 1H on a 1.2 ChannelMaster in Israel but there is no sign of Euro1080. Geoffrey C | ||
| Specialist Contributor Join Date: 01-01-2000
| Sorry to say but your dish is to small for the stable reception from Astra 1h at your location This transponder is located on the Astra 1 H satellite for normally Europe reception Only Additionally the signal is HDTV 1080I format requiring specific recieving equipment due to the hi bit rate of the transmission - M= 18 MPS Max is 40MBS It is not impossible at your location but potentially a very expensive option I would suggest. best regards Old Satellite | ||
| Guest
Posts: n/a
| Old Satellite Thanks for your reply My dish may be small but I can get VOX and the RTL services from Astra 1H on 12.188H - I am wondering if the HDTV test transmissions are at lower power. Do you know - or can you say if the signal strength measures lower when seen on a FTA reciever signal strength display. TechiSat make a PC card which does the image processing. Geoffrey C | ||
| Member Join Date: 09-03-2004
| Hi GCohen, I was curious if you were lucky in your quest for Astra 1H. We're also trying to receive Astra 1H from Rosh Ha'ayin in Israel, but cant receive the transponder we're interested in (TP87) using the 1.80 Meter dish we have. I thought it might be possible to receive this transponder using a 3 Meter, or at worst, a 4.5 Meter dish. We need this in order to monitor a channel we're broadcasting in Germany (VIC-TV.NET DE1). Feel free to get in touch with me Bezalel (bezalel@screenpeaks.com) | ||
Similar Threads | ||||
| High definition test transmissions | Satdude | Daily Satellite and Broadcast industry News | 1 | 28-05-2006 06:49 AM |
| test | Schnuffi | Test Area | 5 | 19-03-2004 10:07 PM |
| Transponder update 17/10/03 | Satdude | Transponders & channels | 0 | 17-10-2003 08:41 PM |
| HDTV (High Definition TV)Test transmissions on Astra 19.2 | rolfw | The Meeting Place | 5 | 14-09-2003 04:38 PM |
| Take the DEATH TEST | net1 | The Meeting Place | 2 | 25-08-2003 11:02 PM |
