Bad reception on Channel U (Sky 467)
Thread Tools Display Modes
Old 30-12-2003   #1
Question Bad reception on Channel U (Sky 467)
Is anyone else experiencing bad reception on channel 467?
I get jerky digitised images and sound intermittently (every few secs!).
It used to be okay, but has recently shown the above symptoms.
I receive all other channels without problem.
I have removed my sat card, and makes no difference.
Would a damaged satellite cable cause the above symptoms (ie affect a specific channel)?
By the way, reception at a friends house a mile away is perfect.
Any help much appreciated.
solara is offline   Reply With Quote
Old 30-12-2003   #2
rolfw's Avatar
Check here http://www.lyngsat.com/packages/skyuk.shtml and see what other channels you can get on this beam without the pixellation, it comes from Eurobird on the Europe NW beam.
It may be that your dish is just slightly off beam, might be worth trying your friend's receiver on your dish..
__________________
Rolf
Donate
Old 02-01-2004   #3
Spot on rolfw !!
I get similar pixelization on other eurobird progs (very useful weblink).
My next question, which of these is the most likely culprit? And can I rule any of the following out?
1.faulty LNB
2.dish allignment
3. damaged co-ax cable?
Can I re-align the disc myself?
I have a spare sat cable running to dish (for future sky+ use). I will try and use that co-ax first, beforehand.
Thanks for your help.
Old 03-01-2004   #4
aka Skyman
Zorba's Avatar
My System: 3m(sky),1.8m(astr/hotbird),1m (nilesat)1m(arabsat)diseqc 4,sky plus,humax freesat,visionet 8000s,technomate 5400 ci+ usb super. Satlook nit colour + Horizon hdsm. wii
If its only Eurobird channels that are problematic,then maybe the dish needs slight adjusting left or right.Try pushing the dish slightly with your hand on either side and see if the picture improves.if not check connections,if not try new lnb.
Zorba is offline   Reply With Quote
Old 03-01-2004   #5
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Solara
Where are you situated? What size of dish are you using?
It may be that you need a larger dish if you are outside of the normal footprint for Eurobird.
PaulR is offline   Reply With Quote
Old 05-01-2004   #6
I am situated in W. London, and I have the standard sky minidish with single LNB. It used to work fine, and then I started getting the pixeliisation. Still havent got round to swapping my spare sat cable. Although I suspect dish/alignment or lnb is causing my problem. Will keep u posted.
Forum Jump
Similar Threads
NTL to launch channel on SKY net1 B Sky B Digital and 28.2 East General 0 06-02-2004 09:39 PM
Changes To Sky Movies net1 B Sky B Digital and 28.2 East General 0 20-10-2003 07:00 PM
Transponder update 20/10/03 Satdude Transponders & channels 0 20-10-2003 04:52 PM
Adding channel 4 and UTV in Ireland onto Sky Digital tdavitt Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 1 20-08-2003 12:35 PM
Solus Cards zansi B Sky B Digital and 28.2 East General 1 06-08-2003 01:22 PM
