Relative merits of antennas | |
| Wineguard used to be a good make, but I believe no longer manufacture. They did make solid (petalised ) and mesh versions of antennas from 70cm all the way to 3.7m, fixed and with polarmount Do you have a particular model in mind ?
__________________ There is a very fine line between "hobby" and "mental illness" | ||
| Member Join Date: 22-02-2004
| No particular type in mind, the used antennas I have inquired about all are made of segments of perforated metal plates. Perforation with holes of about 0.1-inch diameter. Do they offer the same effective gain as solid antennas of same type? | ||
| | #5 | |||
A mesh dish will not perform as well as as a solid at Ku for three reasons 1) The design of the segmented antenna for mesh usually means the parabola is formed by compression in the frame, rather than by manufacturing process, leading to performance as a result of quality of installation. 2) The flexibility of the antenna surface under normal wind conditions, the parabola has a built in distortion, better for survivability, but not for performance 3) The mesh holes can affect signal through aberations and breakthrough of undesirable noise from the rear of the reflector If you calculate about 75% of the efficiency of a solid dish, you wont be far off.
__________________ There is a very fine line between "hobby" and "mental illness" | |||
Similar Threads | ||||
| Tiny spherical antennas | Skip Channel | The Meeting Place | 22 | 06-02-2006 02:21 PM |
| Cheap antennas replace costly dishes | easysat | Daily Satellite and Broadcast industry News | 6 | 13-06-2005 01:10 PM |
| Defects of Installation Satellite Dish Antennas | al_madhi | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 1 | 26-10-2004 07:51 AM |
| Satellite Dishes | T24 | FAQs & Glossaries | 1 | 20-08-2004 05:36 AM |
| 28,2 east relative to horticulture | anton | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 23 | 28-11-2003 01:25 AM |
