Titanium 1 how to clear D+ | |
| Specialist Contributor Join Date: 16-01-2005 Location: Lancashire
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought. |
How to clear D+ using a Titanium 1 card (Tit card) and Dynamite Programmer 1. Make a file on your desktop called Titanium 2. Download the file named Tita1_Nagra2_D+ dated 31-10-07 to this desktop file 3. Download the file named S007 Tita1 Nagra2 v1.04 FIX 07102007 to the same location 4. Open S007 Tita1 Nagra2 v1.04 FIX 07102007 and press “load file”and direct it to Tita1_Nagra2_D+ the default indent should be 4101 in the ideakey 00 box insert todays D+ keys then save the file 5. Insert your Tit card in the Dynamite or similar programmer and open Cas Studio programme goto the tit1 section and load the flash and eeprom from the saved file named Tita1_Nagra2_D+ and that’s it job done each key change simply repeat this process using the current D+ key My thanks to 2 forum members for their help with this matter | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | does d+.not use mecm,like premiere,that it still working on titanium 1? this antmel chip does not support mecm?! card change,is now in december! | ||
My System: Triple Dragon with a Steerable 1 metre Dish with & Diablo wireless & Dragon cam ver 3 & 4 card a matrix rev a cas3 and a load more stuff the wife doesn't know I bought. | At the moment I have Taqilla films Nat geo & fox and all the disney channels open with this file | ||
| clear, titanium |
