titanium card not working in cccamDiscussion on the new breed of satellite TV "Super Cards" | |
| Member Join Date: 06-05-2007 Location: belgium
My System: DM800 on HDTV |
hi, i have a titanium card with OS 1.6 and loading the cabo files to it but when i put it in the cardslot of the dm 7020, i cannot see the card. do i have to make some changes in the cccam.cfg file? i have a DM7020Si with cccam. 2.0.9 in it. and use Gemini 4.4 any help really appreciated.. regards keydember | ||
question is not if cabo files are working but why i cannot see the card in the dreambox! please keep this thread for the titanium problem. not for the cabo problems. for cabo problems, make a new thread. ur answer is useless for me. regards keydember | ||
There is little or no reason to speak to another member in that tone for a simple mistake keydember, I would appreciate a little more tolerance from you | ||
| | #6 | ||
| Specialist Contributor Join Date: 25-04-2005 Location: Austria
My System: 1,25 Fibostop Jäger Smr 1224 & Smo 36 Dual Axsis Motor Dynasat F1 Monterey 140 Drembox 800 sky Pace HD Box Tagra 2,20 M Fullsize Dish Echostar 2,40m Mesh for cband! | Hello! never tested it in ccam,only using penta ci 1,09 and it works great ! | ||
| | #8 | ||
| Manic Midlander Moderator Join Date: 24-09-2006 Location: West Midlands. UK
My System: Dreambox 7020si, Technomate TM600, Technomate TM9100 Fracarro Penta 85 Dish, Televes 0.6dB Quad lnb, TM SG2200 motor. 60cm Channel Master BSB dish on 28e, Mti Blueline 0.2db Twin Lnb. Rover ST-4 Meter Cyfra+ Subscription | Dunno mate, i can't get that card you gave me to work either ![]() Even ye olde Matrix cam is sticking its fingers up at it ![]() ![]() Nano | ||
Sanity is nothing more than an excuse to be boring <<<<<<<<****** Dreambox DM7020 Si , S.I.F 1.9.3d ******>>>>>>>>> <<<<<<<<******** Technomate TM9100, EDG 4.4 ******** >>>>>>>> <<<<<<<<<<******* Technomate TM600, UR 23 *******>>>>>>>>> | |||
| | #9 | ||
| Specialist Contributor Join Date: 01-01-2000
| I will repeat the post I made over a year ago. If someone posts a link to working Cabo Titanium files I will test them out and see what I can do. Of course, and in case of any doubts, I would check they really are working cabo files before bothering with the dreambox. | ||
| card, cccam, titanium, working |
