Help with M2+ programmering!
Old 06-09-2008   #1
My System: DVBViewer and DVB-S
Hey,
I buyed a M2+ card and CAS3+ programmer...
I'm trying to program it by phoenix (3.579Mhz) and the m2plus programmer...
But i keep getting the same error : "Unable to restore OS, check your card"... I had tried diffrent Com ports in the program and using diffrent delays... nothing working...
Anyone know what to do?
Please help!
//THUNDER
thunder2008 is offline   Reply With Quote
Old 06-09-2008   #2
How have you got the serial cable connected to your Cas 3+ programer?
The Cas 3 requires both a USB cable and Serial cable to program in phoenix mode, if your PC/Laptop doesn't have a dedicated Com port and you are using a USB-Serial adapter you might need to go into Device Manager and allocate a Com port between 1 and 4 to correspond with the MII+ software.
Mickha is offline   Reply With Quote
programmering
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
