Knot card 2.Discussion on the new breed of satellite TV "Super Cards" | |
| Member Join Date: 14-04-2005
My System: echostar 808 hp pc |
Hi.Could anybody please assist me with some information.I have a knotcard2 I have downloaded a file signed by persons calling themselves the anti knot card team.the result is it has changed the OS from 3.5 to 0s 2.0.how can I rectify this Regards seanmarg. | ||
My System: echostar 808 hp pc | Thank you for the quick response.I have a dynamite programmer.when the card is inserted it states quite clearly knot card 2 OS version 2.0.the card is knot 2 and was not a problem before.I loaded a seca 2 file and the message came up "bye bye"the anti knot card team.I started to load a proven file using the knot 2 loader as well as on the Dynamite screen it states clearly on the knot2 loader screen OS 2.0.whatever this team programmed in it has changed the OS. I would be grateful for any advice on how to reverse the card back to 3.5OS Regards.Seanmarg | ||
| Specialist Contributor Join Date: 01-01-2000
| There never has been OS 2.0 on any Knot card, either Knot1 or Knot2. I guess you have loaded a fake file. Does it still say if the bootloader is 2.0? If yes, you could try loading the genuine OS3.6 file to see if the card accepts that. | ||
| | #5 | ||
My System: echostar 808 hp pc | Hi I have tried loading files using loaders 1 and 2. I noticed they had changed the ATR It still does not work .I think the bootloader has been affected how can I get it rectified back to 2.0.Regards. | ||
| | #6 | ||
| No one can change the bootloader so it's impossible that you have changed the bootloader by accident, even with a fake file. What do you see displayed in kcloader v1.0 when you connect to the card and see the ATRs. | ||
| | #7 | ||
My System: echostar 808 hp pc | Hi.I have a cas 2 programmer without phoenix activated my card is recognised by cas as knotcard 2 card OS VERSION 2.0. With phoenix on kc loader 1.0 it distinctly shows 2.0 on the card directly above the chip. The 12th and 13th set of numbers on the ATR have been changed.I have also tried to load using KC 1 loader the card is still recognised as an OS 2.0.I had been informed from another source that the bootloader was suspect.you obviously know better. Many thanks can you suggest a way to revert back to OS 3.5.Regards | ||
| | #8 | ||
Hi. After many tries I have finally found an OS update which actually works you was correct in stating that the bootloader was not affected many thanks for your advice.Kindest Regards. | ||
| card, knot |
Similar Threads | ||||
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| BBC (Sky) FTA Card What card does what ? | ShayK | Sky Digital (BSkyB) and Astra 28.2 East General | 5 | 26-01-2005 06:42 PM |
| hang on " sending TRAPCODE" and a new titanium card | hfathollahi | Cards & Programmers General | 22 | 18-12-2004 08:00 AM |
| Pentamedia card not initializing | s*t*a*r*m*a*n | Computer Discussion | 1 | 14-07-2003 05:07 AM |
