k3 card programmer
Old 12-08-2006   #1
Frogman33's Avatar
My System: Digiquest 6700 embedded ucas rcvr /hotbird and Astra
k3 card programmer
2 program the k3 card what do you need ? Will a cas 3 in phoniex mode do it or do you need a infinity programmer? thanks
Frogman33 is offline   Reply With Quote
Old 12-08-2006   #2
Hi Frogman33,
in theory a Cas 3 should be capable of programming a K3 card, but unfortunately in practice, some people have experienced problems, while others have got it to work simply by putting the Cas 3 in phoenix mode, under utilities.
Duolabs are working on updated software, but the best you can do is try it first.
Best wishes
Mickha
Other people are also experiencing problems with some older phoenix programmers, hopefully there may be an updated K3 loader that will work, depending on the support for this card.
Mickha is offline   Reply With Quote
Old 12-08-2006   #3
Frogman33's Avatar
that will be great if the do...k3 loader
So I'll just wait on getting the card, until I here something more solid on the programming. thanks
card, programmer
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. Uptime monitoring by PageUtils.com
