HELP with K3 and infinity USB | |
| Member Join Date: 22-06-2005 Location: england
My System: pc |
Ive put my infinity usb into virtual mode and set to phoenix 3.58. But when i load up the K3 loader i just get the error message - unable to restore OS, check your card!! argh!!stressin me out | ||
| Member Join Date: 23-07-2005 Location: Ireland
My System: Motorised also one fixed with 19/13d arm and one fixed on28d E, os windows 2000 |
You must set your com port the same way in VCP mode and also in k3 loader, for instance when you select VCP you will see a tab to select com port s, select either 1,2,3,4 and enable, now run K3 loader on the top right corner set com port the same as set in VCP mode then it should work | ||
| infinity, usb |
