titanium 2 card o/s 202
Discussion on the new breed of satellite TV "Super Cards"
Old 18-12-2006   #1
My System: dtv
Originally Posted by ive303422
hi i have a tit2 card new with os 202 on it can i down grade to 201 as cryptkey will not load on 202 but does on a os 201 card hope you can help many thanks ive
ive303422 is offline   Reply With Quote
Old 19-12-2006   #2
john_graydon's Avatar
My System: Dusty Dreambox 7000s, & Sky HD.
2.2 O/S Cryptkey will load. Done it about 20 times last week using different files other than Satellite. Make sure its the Crypt key you are loading. Try erasing the card 5 times and try a different set of files again. If it loads on the Opus it should load on the Tit2 card.
Happy Dreaming
john_graydon is offline   Reply With Quote
Old 20-12-2006   #3
My System: dtv
have tryed that but gets to 90% then stops but i might be doing something wrong or have the wrong keys ......
Old 28-12-2006   #4
Do you have a usb phoenix loader? if so,go to preferences and set "load at startup" to on.Had the same prob.but when it loads on startup it will work !
Give it a try
garfield57 is offline   Reply With Quote
202, card, o or s, titanium
