Technomate 6800 - No sound on HDHigh Definition Technomate HD satellite TV receiver help and support forum. | |
| Member Join Date: 08-04-2007 Location: Essex UK and Menorca, Balearics.
My System: Technomate 1500 C1 1.3M dish (offset) in Menorca. Technomate 6800 HD 90cm motorised dish (offset) in Essex |
I've just installed the 6800 and it performs superbly for SD channels (pics and sound) but when I view HD channels (on Astra 28.2E) the picture is there but no sound. What do I need to do? | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, Try selecting a different audio track, see if that fixes it. | ||
| Member Join Date: 02-04-2005 Location: north east england
My System: Triax 1.1mtr cryptic H-H Technomate 6900 technomate 6900super TM9100(UR18 image) eagle (v5 image) | I think you need to select pcm in the audio options ? | ||
| The Following User Says Thank You to spartans For This Useful Post: | perry266 (08-06-2008) |
| | #5 | ||
My System: Technomate 1500 C1 1.3M dish (offset) in Menorca. Technomate 6800 HD 90cm motorised dish (offset) in Essex | | ||
| | #6 | ||
| | #7 | ||
| Specialist Contributor Join Date: 11-12-2004 Location: yorkshire
My System: channel master 1.2m dish technomate 6900,,and invacom 0.3 quad lnb satlook micro | thanks perry is that both hd and sd pcm=In the digital domain, PCM (Pulse Code Modulation) is the most straightforward mechanism to store audio. The analog audio is sampled in accordance with the Nyquest theorem and the individual samples are stored sequentially in binary format. The wave file is the most common format for storing PCM data. But, before you dig into the internals of wave files, it would help to get some insights to the Interchange Format Files that form the basis for the wave file format. | ||
| The Following User Says Thank You to iwol For This Useful Post: | perry266 (09-06-2008) |
| | #8 | ||
My System: Technomate 1500 C1 1.3M dish (offset) in Menorca. Technomate 6800 HD 90cm motorised dish (offset) in Essex | Yes, the 6800 is both HD and SD (MPEG2 and MPEG4). Selecting PCM in the Audio menu solved the sound problem. Thanks. | ||
| 6800, sound, technomate |
