HD Receiver to 2 tv's??High Definition Technomate HD satellite TV receiver help and support forum. | |
| Member Join Date: 01-07-2008 Location: UK
My System: No Setup Yet |
Hi, was wondering if I can use both the component and hdmi outputs to 2 different tv's?? I want to use component to tv in living room, and hdmi to run through to projector next door..?? I can use one of the ir receivers so I can use the remote in a different room, but I dont want to use a tv-link as I want to provide as good a source to both the tv and projector... so I can basically eatch satellite in either room.. if the missus is watching cable in the living room etc.. Thanks | ||
| Member Join Date: 31-05-2006 Location: london
My System: TM 6900 | Yes you should be able to use both component outs and HDMI simultaneously. I can on my TM 6900. If you're using a Sky HD box you may find however that the component outs may not work on some programmes and channels. | ||
| receiver |
