problems with high def freeview
Thread Tools Display Modes
Old 04-12-2007   #1
bog standard
moosegoose's Avatar
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2.
has any one herd of some problems with the trials of high def freeview in regaurd to the amount of band width they will use. parogon are in the proccess of developing v and h polirization aerial.as this may be the only way to get hd on freeview.if this is true all these nice digital aerials we have been fitting will be redundant.or will we be fitting hd aerials along side the digital ones.
moosegoose is offline   Reply With Quote
Old 04-12-2007   #2
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
We already use the distinction between horizontal and vertical polarisation on terrestrial signals. The main transmitters are horizontally polarised and repeater stations are vertical. This ensures that we (hopefully!) get the maximum usage of our linited radio frequencies.
I don't understand what Paragon are doing. Do you have any information?
I don't know for sure but I'm fairly certain that HD will be in MPEG4 which is more efficient in compressing a signal than MPEG2, as used for SD digital. As a result HD occupies almost the same bandwidth as SD.
__________________
As I get older I find myself thinking about the hereafter - I go into a room and then wonder what I'm here after.
PaulR is offline   Reply With Quote
Old 05-12-2007   #3
bog standard
moosegoose's Avatar
acording to the source of my infomationb there a problem fitting it into the 8 mhz slot. there for are considering v and h pol from the same transmitters to over come the problem.as you say there should be no problems. but real world tests have proved otherwise.
Old 05-12-2007   #4
PaulR's Avatar
Ah, now I understand. What they mean is transmitting both vertical and horizontal components so that it doen't matter whether your aerial is H or V.
Most (all?) FM radio stations have done this for some years now to cater for home aerials which are traditionally horizontal and cars which are vertical.
__________________
Old 08-12-2007   #5
bog standard
moosegoose's Avatar
i presume digital freeview on horizontal and digital high definition on vertical.which means additional aerials or a aerial with both which is in development.
Old 08-12-2007   #6
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Interesting. Any info on this moosegoose?
Maybe some control of polarity will be needed in the STB as the aerial presumably will need to be switched between H & V?
__________________
Llew is online now   Reply With Quote
Old 08-12-2007   #7
rolfw's Avatar
Well that would be a popular move. . . . . I can just hear the phone calls now.
__________________
Rolf
Donate
Old 08-12-2007   #8
PaulR's Avatar
I still think some information is missing here. I've been to the Paragon website but as I'm not a registered member can't get any information. Looking at their products on the SCC site I don't see anything special there (apart from the rather delicious 1.2m parabolic!).
Adding Horizontal to Vertical doesn't give an extra amount of information sent. It will surely only increase the likelihood of good reception.
Can you be a bit more specific Mongoose.
__________________
Old 08-12-2007   #9
Mod and septic resident
Channel Hopper's Avatar
Who knows, they might plum for circular polarisation
__________________
Old 08-12-2007   #10
Sky Remote Breaker...
2cvbloke's Avatar
My System: Mostly gathering dust cos I'm a lazy git. Porty dish face blew off the mount, not too pleased...
The Sleepy Hollow pollracle has spoken!
How in the monkies would that work??
__________________
I think your car looks funny too......
Proud owner of a satellites.co.uk cap & T-Shirt...
Resident KIRBY Vacuum nut...
2cvbloke is offline   Reply With Quote
Old 08-12-2007   #11
PaulR's Avatar
Circular polarisation can be imagined as a dipole aerial transmitter that rotates once for every cycle of frequency. Therefore there's at least sometime during the rotation when the receiving horizontal or vertical aerial will be in line.
I think the loss in strength is 3dB but the gain is that, as long as the aerial is pointed in the right direction, then there will be a constant signal.
__________________
Old 09-12-2007   #12
Llew's Avatar
OK if the receiver is just for HD, but presumably it'll be a combined HD/SD box, in which case it'll need to be able to switch polarities.
If an aerial is definitely being designed for combined H/V transmissions, then presumably the STB manufacturers are working on this.
All conjecture though until anything more is known.
__________________
Old 09-12-2007   #13
rolfw's Avatar
I'm not sure why there would be a need for switchable polarities, I can't see the advantages.
Digital signals, can sit on adjacent channels of the same polarity.
__________________
Rolf
Donate
Old 09-12-2007   #14
Llew's Avatar
But surely the receiver will then only see half the channels in the mux?
The LH and RH polarities received by the circular aerial have, as with H and V, got to be somehow recognised by the STB.
__________________
Old 09-12-2007   #15
ZZ Mop
j..m's Avatar
My System: Sky Digibox Pace 2200, 3 remotes, 2 mice, 2 splitters, a amp adder thingi, a Thomson universal LNB & a zone 2 dish..... With foamy whatsit coax
I have been trying to adapt my chimney to accept a horisontal polarisation antenna ..... However the bricks keep falling off & bouncing down to floor level ...... Maybe I should construct a horisontal chimney on the ground & kinda carry it up & mount it ? .... Woddo ya think ?
__________________
Mary had a little skirt
With splits right up the sides
And everywhere that Mary went
The boys could see her thighs.
Mary had another skirt
'twas split right up the front
..But she didn't wear that one often.
j..m is offline   Reply With Quote
Old 09-12-2007   #16
2cvbloke's Avatar
Have you tried just turning the aerial on it's side?
__________________
Old 09-12-2007   #17
ZZ Mop
j..m's Avatar
Now ya just being silly
__________________
Old 09-12-2007   #18
2cvbloke's Avatar
Sillier things have happened, like satellite dishes on their sides and upside down dishes, plus to make an aerial Horizontally polarised, you turn it 90 degrees from vertical...
__________________
Old 10-12-2007   #19
ZZ Mop
j..m's Avatar
Ya can do tha "Ye olde" lie the dish on its back trick tho ....... Or am I thinking of summink else
__________________
Old 10-12-2007   #20
2cvbloke's Avatar
There's the upside-down method too, I've not tried it yet...
__________________
Old 10-12-2007   #21
bog standard
moosegoose's Avatar
sorry for not replying sooner ive been rather busy.there is nothing on the web site.i saw the aerial in the boot of a car and wanted to know what it was for.at first he clamed up then he started on on about how they could not get the harmonics right and so on.which compleatly lost me. but the long and short of it is. due to problems with hd on terestrial paragon feel there is a need to develop this aerial.if they will ever need it is another matter.my personal opinion is hd will never be recieved through a aerial.or a very limited amount.but with the launch of freesat in march do they rearly care.ps i dont have any pics to back up this it just looked like to aerials stuck together with no balun/dipole every element driven.
Forum Jump
