4 way mast head remote power on all points
Thread Tools Display Modes
Old 05-04-2008   #1
bog standard
moosegoose's Avatar
My System: 80 cm dish hh motor teco tm1000 dreambox 7020 cas 3interface dragon cam.promax tv explorer 2.
hi i was looking for a external amplifier with up to 4 ports which can be remotely powered from 4 town houses. so they can all use 1 aerial. i have used antiferance 4 way mast head with variable gain which can be powered from any output. but can all so be powered from all of them although this is not what it was designed for. i checked with antiferance and the said although it was not designed for that it has been used for that application with no problems. my concern in using this amp in future was a recent artical on sharing satellite dishes and and problems if the electrical supply is not on the same phase. i not sure if this will effect a shared amp powered remotely from 4 separate dwelling. i have done a goggle search with no luck.
moosegoose is offline   Reply With Quote
Old 05-04-2008   #2
Information Exec
satelliteman's Avatar
Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
If your considering installing a shared aerial/ communal MATV system, even though it's only 4 outlets, don't forget to earth the input and outputs cables to the PME (primary main earth) as per BE EN 60728-11.
Old 05-04-2008   #3
bog standard
moosegoose's Avatar
do u think earthing would be necessary as it is not a public building just residential.
Old 05-04-2008   #4
rolfw's Avatar
Not sure how well you can earth it, as there would not be a common earth to the houses.
It is certainly not something I would recommend, how good is the reception in that location? Would it be good enough for a super high gain antenna and a passive four way passive masthead splitter (normal insertion loss around 7db)?
__________________
Rolf
Donate
Old 05-04-2008   #5
Information Exec
Isolated outlet plates could be used to prevent the transfer of dangerous voltages through out the cable network between outlets. EMC codes apply. The provision of isolation OR earth bonding is intended to provide protection by ensuring that is either prevented from entering the system OR is disconnected by the operation of the appropriate over current protection device RCD.
All types of master Antenna Television distribution systems need to be earthed as per 60728-11:2005 standards, even only 2 points if it's a separate dwelling (MDU's).
I have to disagree with you here Rolf, I'm afraid.
New standards will be coming in very soon regarding the earthing of larger domestic systems with more than 4 'IF' outlets.
Example:
One dish with QUAD LNB feeding 4 townhouses with a single 'IF' feed.
This system will need to be EARTHED.
Old 05-04-2008   #6
rolfw's Avatar
Yes, but what I'm saying is, the four houses will not have a common earth, they will have four separate earths and I'm not sure how that would affect the RCDs in the different houses.
It would be far better if a passive system is possible.
__________________
Rolf
Donate
Old 05-04-2008   #7
Information Exec
A valid point Rolf but a touchy subject
A passive system would work in this case as long as no amplification was required for the correct signal levels
I would at the very minimum, provide isolated outlets on the above installation as it's a shared system.
Forum Jump
