Help with aerial siting, and planning law...Information exchange on Freeview, Freeview HD, Digital Terrestrial Television and analogue broadcasts. | |
| Member Join Date: 12-06-2007 Location: Cheshire
My System: IBM R51 |
Hello, Please let me begin by stating that this post is about TV / FM aerial installation. I know this is a sat forum, but there's loads of installer expertise here and I'm hoping that you might be able to help. Well........today has been interesting. Took the day off work. Hired some 9m ladders from HSS (£40 delivered). Went to work on the gable wall of my house, installing a T&K \ 2 inch aerial pole (10 foot) and 4 aerials (YagiFM, Omni FM, DAB, TV). Moved all the cables in the loft, drilled the exit hole in the wall for the cable, got the aerials mounted on the pole, all aligned correctly (relative to magnetic north), so when installed on the bracket, I'd just have to align the pole up to Mag North. And while I was up the ladder trying to get the pole \ aerials in the T&K.......... People started coming out of there houses shouting from below that I'd better not be mounting 'that monstrosity' on the gable wall, because I'll be reported to the council. There were 4 people from 4 different houses crowded round my ladder FFS. By now you have probably guessed that I live on a residential housing estate, and that I have other houses surrounding me. A picture of the pole aerial(s) can be found here: http://www.satellites.co.uk/satellit...2&d=1210364972 All the earials would have projected above the roof line of the house (1m). A big part of the problem (I think) is that all of those complaining open there master bed curtains onto my gable wall. So they'll see the aerials - oh - and their houses are up for sale. When I asked what would be acceptable in their eyes on the wall - fewer aerials, thinner pole etc.. nothing. Not even a dish. I've looked at mounting the pole in other places (4 sides to my house). Can't do the front (think there is planning law against that). Can't do the back (can't get over the conservatory roof without scaffolding - £££££££). Can't do the remaining side because the aerials would be below the roof line and pointing into a neighbours roof - rubbish reception. Lots of other people on my street have multiple aerials on poles (attached to the chimney - not a gable wall)), and they all extend way above the top roof line. You have to do this in my area for good reception. No matter where I mount the pole, someone is going to complain. There're just too many house proud people in my neighbourhood. So I'm going to have to keep to the letter of the law. I plan to ask the local council planning dept, but I had to deal with them for an extension, and they are fussy as heck (cheshire), and I don't trust them (had to go to appeal - and won). My question is; where do I stand legally when fitting aerials? Is there a limit to how many you can have on one pole? What about permitted development rights for aerials? I have searched the forum, but couldn't find any guidance on this matter for aerials. If it's the same for dishes then I have a starting point. Thanks. | ||
| Last edited by Robbo; 09-05-2008 at 10:32 PM. Reason: Uploaded picture rather than linking to photobucket | |||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, I'm pretty sure there is a document available online regarding the siting of antennas etc and I think it has been uploaded to the forum somewhere, I'll see if I can locate it. Robbo ![]() Edit:- New UK Dish Planning Guidelines and the document below an interactive guide:- http://www.planningportal.gov.uk/upl...nna_guide.html | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | This thread indicates the dish laws apply to aerials as well New UK Dish Planning Guidelines (note point 9) No-one in their right mind complains about tv aerials - I cant see anything too objectional about that antenna array. Personally Id put it up and sod them - at the very worst the council could ask you to take it down again, at which point you could rethink what you wanted to do. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | That isn't an exceptionally large array and unless there is a specific enforcable covenant on the estate against such aerials, there is pretty much nothing they can do. One question though, why the yagi and omni for VHF? | ||
| | #5 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | I thought that too. Ditch the omni.... keep the directional The rig is nothing out of the normal that installers like myself install day in day out in all housing estate locations. ps. consider changing the contract uhf to a high gain benchmarked aerial | ||
| | #6 | ||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | Personally, I'd say stick it up and sod 'em, if they complain, tell them to go take down their own aerial masts too!!! It's only fair that they can't have TV & radio reception if you can't... | ||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | |||
| | #7 | ||
My System: IBM R51 | Hi, Thanks for all the replies. I want the omni and the yagi FM because all of the FM stations I listen to are not broadcast from the same transmitter. I thought I would use the omni for good signal strength stations and the yagi for further afield (= weaker) stations. I have an FM receiver with A and B ant input so I can switch between. Poor signal to noise transmission has a poor sound on FM. I put the DAB in there so I wouldn't have to go back up when the changeover eventually happens. I've read the rules, and it looks as though I'm fairly wide of the mark. 1. Only 2 aerials allowed (I've got 4). 2. Cannot extend above the roof line (my chimney is below the roof line). Even in light of the above, plenty of my neighbours (even those complaining) are breaking the same rules (height \ number aerials). As with all disputes, to win, you have to go from the top down. I'll request a ruling from the local council and ask their advice. The service is not a formal planning application, but it does cost 10 quid. Once I've got that, I'll also get the permission of the freeholder. Then I'm bulletproof. Thanks. As an aside; I asked those complaining what I would have to do in order to compromise. The replies were: 1. Use a thinner pole (1inch). I told them it would blow down in high winds. Not interested. 2 inch is too ugly. Looks like scaffolding apparently. 2. Make it look less like a taxi mast (WTF?). Was also accused of being weird for wanting such an array, that looked so ugly. No normal people have such installations according to those offended. | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | The two aerial rule is for dishes, as is the roof line rule, don't think it applies to terrestrial aerials, as they need to be above the roof line to work affectively. You could use a 1.5" galvanised steel mast which would look slightly less scaffold like and perhaps lessen the impact a little, but I would leave it up there and do the checking afterwards. Some people will complain about anything if you let them. | ||
| | #9 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Tell them your run a digital feed into the home ..... I bet that will shut them up. LOL | ||
| | #10 | ||
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! | | ||
| | #11 | ||
| Regular Member Join Date: 16-09-2006 Location: Wolverhampton
My System: Motorised 1.2M Fibo looking between 45E - 60W, TM9100 Receiver running EDG-Nemesis 3.2 in flash | I've just 'Googled' "planning television aerials" and just about every entry quotes - 'Normal domestic TV and radio aerials do not need planning permission'. I would, as others have suggested, put them up and see what happens..... My guess is - nothing will. | ||
| aerial, law, planning, siting |
